Has anyone had condensation problems with new replacement rear lights or do the new replacement lights solve the condensation problem completely?Seems a common problem. When my rear lights were replaced for this, the SC said the replacement criteria they worked to was that any light with just misting wouldn't be replaced, any with visible water droplets would be replaced.
The Tesla view seems to be that misting is acceptable, but persistent water droplets inside aren't. FWIW, when I first reported this the SC looked at the lights and said it was "within acceptable tolerance", with both lights still misted up after a drive of nearly two hours to get to the SC. That suggests that persistent misting is OK, although I'm not convinced that the police would share that view, with regard to whether the rear lights are obscured or not.
The light change is literally a five minute job, they are very easy to remove and replace, apparently. That photo shows clear evidence of water droplets, so if Tesla are still using the same criteria then they should just replace the light.
There are other threads on this, including some discussion about DIY sealing of the welded join between the light components that may the cause of the water ingress. If mine start to mist up again, then I'm pretty sure I'm going to try sealing that join, as I'm not convinced that the cause of the problem has yet been resolved, and the new lights may be just as susceptible to leaking as the ones they replaced, perhaps.
Is that on a replacement unit?Yes, misting is back in my right rear light, but not yet in the left. At the moment it seems to be below the "droplet threshold", and clears after a few hours of dry weather.
