Destiny1701
22’ M3LR ‘DrkNite’/ 22’ MYP BliueRocket
Never had this issue with LR boost.Don't buy an LR AWD thinking you're going to really power out of turns like an STI or Evo or something of that nature. Mechanically the AWD Model 3's could but the traction control won't let you until the steering wheel is pretty much straight. That's my experience across a couple models (LR AWD, LR RWD, and P outside of Track Mode).
It's kind of a weird experience. For example if there's a two lane 180° ramp the stability control usually gives enough leeway to pass someone on the outside lane, but then you get to the end of the ramp and try to stomp on it early for the merge...and the car barely trundles along. Like a tiny gas engine that's out of breath. Get the wheel straight and suddenly the power is back.
When the steering wheel is straight, after you've exited the turn, then the LR AWD can really put its power down and use all that traction. If someone here has a Model 3 (any kind, AWD or RWD) that lets them really power out of a turn without using Track Mode, I'm interested to hear, as that's not been my experience nor that of a friend with an older Model 3.
Instant power on demand regardless of steering angle. I hit the pedal just coming out of a turn or even partiall mid to exiting and bam…flies..
