Consistently overstating remaining range
bob_p
3,614
2,755
It's very likely we'll see future improvements in the range estimates for trip routes, taking into account up-to-date traffic data, weather conditions, and elevation changes. This will be needed to support FSD to ensure the AP software is able to reach the destination, including intermediate charging stops.
Until then, when taking trips we'll usually make our own range estimates before leaving a charger, to ensure we have enough cushion to drive to the destination or next charger without having to monitor energy consumption and slow down to extend the range.
A simple rule we'll use to validate the onboard software's range estimate - take the miles to the destination/next charger, add 20% (higher if facing strong headwinds or large changes in elevation), and then add 20 to 40 miles to keep the charge from getting too close to 0%. If our estimate indicates we need more charge, we'll use that to add more charge before starting.
The other rule we use is using the trip planner to estimate % charge at destination. While the trip planner may be comfortable in predicting around 10% charge at the destination, we often will wait until the predicted charge at destination is at least 20% (more if high winds or elevation changes).
Using these simple rules, we've been able to avoid having to slow down on routes. And if the above rules indicate the current charge is below desired levels (which happens if you're trying to make a long hop to the next charger), it's better to slow down a little earlier in the route, than waiting until the software warns you about a risk of running out of charge - and then having to slow down much more to reach the next charger.
Reactions: Sawyer8888
Rocky_H
5,908
6,783
Boise, ID
Change the range setting to % and ignore the incorrect estimate. If you want an accurate estimate, set a nav destination and use the energy app's trip tab. That's dynamic and accurate.
Change it from miles to percent and you’ll be much happier. Use the energy graph to view your predicted range. You’ll be much happier. :)
Well, that is a holy war. It actually says much more about someone's own personality type when they express it in terms of being "happier" or "less stressed" or "not worrying". Many people who prefer rated miles are just very easygoing and unbothered and don't get "stressed" or "unhappy" with the distance being a little inaccurate.
It's a basic difference, where some people hate rated miles because they see a distance, but it's not exactly accurate as a prediction of the real distance, so it gets under their skin and drives them up the wall, because that seems wrong.
The other side of the coin is that % is just uninformative, so I and many other people don't like that. Humans think in terms of how far away something is, not how many percent away it is. So rated miles is at least something that's useful to you, with some acceptance that it's a little high.
Here's a whole thread on this controversy:
State of Charge: Percentage or Distance?
Reactions: MorrisonHiker
Rocky_H
5,908
6,783
Boise, ID
Have you disliked every gasoline vehicle you've driven for this reason as well?
Hmm, funny how you exaggerate a preference for a type of fuel gauge to disliking an entire vehicle for that. I have never had a gas vehicle with any kind of "distance remaining" estimator available, so you use the information it has, and there is no liking or disliking it.
Mediocrates
362
347
San Diego, CA
I will restate based on your previously asserted opinion: did you not like having a percentage of fuel display in every gasoline vehicle you've ever driven? Did you consider it uninformative?
Rocky_H
5,908
6,783
Boise, ID
It is somewhat informative, but not nearly as informative as a value in miles, which I was abundantly clear with previously.
Rocky_H
5,908
6,783
Boise, ID
So the answer is no, you do not find it uninformative.
Do you want a gold star or something?
It's like the original version of the tire pressure monitors. They didn't have the number of antennas to identify the individual tires, so they would just give you a general warning if you had a low tire, but you had to figure out which one. It can't ever tell you the pressure numbers, so it's not very informative, but if that's all you've got, you'll take what it gives you.
cybergates
510
213
So Cal
the way I drive it's never accurate.
1. use the navigation system it always gives a near accurate percentage of how much juice you'll have to the next destination.
2. Range mode ON and standard braking when needing to go the distance.
3. If desperation occurs, turn off AC but leave vent on.
Chaserr
Hyperactive Hyperdrive
Sep 5, 2017
2,652
5,571
Logan
The on-dash miles display is never accurate, it can't be and it's inaccurate on purpose. It's just a % bar no matter what, that is either displayed next to a numeric true % of full, or as an inaccurate EPA number adjusted by used true %, or an an inaccurate Ideal number adjusted by used true percentage. That's it, no big deal. You're required to do math in your head for all of them, no need to argue about it; either you use the real % and figure out real miles, or you use an imaginary miles display that shows incorrect miles and you adjust based on your average correction from that number, or you use the other maginary miles display that shows incorrect miles and you adjust based on your average correction from that number. End of story, there is no accurate mile number on the driver display, if you want one you have to dig it up on teh center display instead.
