Cooling system improvement
Discussion in 'Roadster' started by Doug_G, Mar 19, 2011.
Tags:
  1. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    My Tesla Ranger mentioned to me today that they're going to be doing a modification to the front cooling fans. What they are going to do is install a manifold that covers the entire radiator and funnels the air into the two fans, which will now be standing a little above the radiator.
    The point here is that when the fans run, they will draw air through the entire radiator, instead of just through the area underneath the fans themselves. This will provide a significant improvement in heat dissipation.
    The install requires removing the radiator, which means they have to drain the coolant system. So there's a bit of work involved.
    I have to say this sounds like an excellent idea! Goes to show that Tesla is still putting some thought into improving the Roadster, despite having most of their resources on Model S.
  2. cinergi
    cinergi Active Member
    MA
    My 2.5 is already designed like that. My tech described the same reasons. Not sure when it became standard.
  3. zack
    zack Member
    Minneapolis, MN
    So my born-on 1/1/11 2.5 has improved cooling?
  4. Doug_G
    Ottawa, Canada
    Interesting, I wonder if all 2.5's are like that. Possibly not; Tesla often introduces new updates as soon as they become available. (My late-2.0 has quite a few 2.5 features.) When did you get your car?
  5. cinergi
    MA
    October 2010.
  6. vfx
    vfx Well-Known Member
    CA CA
    I wonder if this is a bulletin for 1,5's as well.
  7. samcarney
    samcarney Sam C
    Great Lakes, Sonoran Desert
    Doug I had this done to my 2.0 Roadster last summer. It was a noticeable improvement.
  8. Doug_G
    Ottawa, Canada
    Very likely. My fans look like this:
    What do yours look like?
      File size:
      80.9 KB
      1,385
  9. samcarney
    samcarney Sam C
    I don't have a picture, but this is how my fans looked BEFORE the mod. The mod includes a shroud that covers the entire radiator, directing all the airflow through radiator. The fans mount to the shroud which raises them about a 1/2 inch.
  10. scott451
    scott451 KWH-PWR#1349Sprt,S Sig#96
    Palo Alto
    Yes! I got it when they did the 24K service. Noticed it yesterday when I washed the car.
  11. TEG
    TEG TMC Moderator
    #11 TEG, Mar 19, 2011
    Not the best example (and not from a Tesla), but I assume you are talking about a fan shroud assembly something like this:
    (now it will match my forum picture better!)
  12. vfx
    CA CA
    Now I need to look. Have not washed it since my 24K service.
  13. cinergi
    MA
    Here's mine
  14. vfx
    CA CA
    Nothing about "per bulletin" or something like that in the paperwork?
  15. mpt
    mpt Electrics are back
    Warren, New Jersey, United States
    What improved?
  16. samcarney
    samcarney Sam C
    During hot humid weather the the air conditioning would not switch the cooling to the battery as often which keeps the cabin cooler. I did not notice any difference in battery temp it stayed the same as before the mod.
  17. Doug_G
    Ottawa, Canada
    Great, that's what I was hoping you'd say.
  18. mpt
    That's what I was hoping for as well; increased efficiency means less time on the batteries and more for me.
  19. vfx
    CA CA
    #19 vfx, Mar 28, 2011
    Befores 1.5:
    After:
    Before 2.0+
  20. jory
    jory Member
    san francisco
    while attempting to track down a weird (fan?) noise problem with my 2.0 roadster (see my posting in the thread: Battery "grinding" sound?) i asked the menlo park service folks about the fan/shroud update mentioned in this thread and was told:
    "During the inspection of the front fans and condenser, if found faulty the upgrade will be added."
