I purchased one of
the corn cob bulbs on Amazon and after reading
this report I requested a refund stating did not emit UVC. The refund was immediately given without a request to return the item indicating the seller acknowledges it was a fake.
If anyone wishes to test it, let me know.
FYI,
@dkemme sent me the bulb and I tested it. Here's what I reported to him - reposting it here since I think it will be enlightening to everyone:
The bulb arrived today, and - as we suspected - it's as fake as a $3 bill.
Now, to be fair, it does indeed put out UVC - but it's totally incidental to the visible light output and is at such a low dosage (.007 mW/cm2) that it would take 7.93 hours to reach the minimum 200 mJ/cm2 considered the most reasonable safe dosage to inactivate 100% of virus particles. Even to get to SAL95 would take over 4 hours - and these figures assume that you are touching the lamp to the surface as I took the measurement with the UVC probe right up to the LEDs. Factor in the inverse square law and it's putting out basically zero - so low the meter can't register it - once you get a few cm away.
For comparison, here are the figures for some other UVC products I have here:
Homedics portable phone sterilizer LEDs - two come in the product - each puts out 1.5 mW/cm2
Chinese cell phone sterilizer from Amazon - two UVC tubes - each puts out 0.4 mW/cm2
My 35W bulb that I used in my project - 18 mW/cm2
In sourcing the UVC LEDs, it appears that even in bulk they are at least $2.00 each - so your bulb, with 347 LEDs on it (I counted!) should be easily a few hundred bucks. Even if it was an $80 bulb, the LED cost would have to be around 20 cents each. And - of course - they don't look like UVC LEDs which have a distinctive casing, as seen here:
E275-60-STRIP
I'm planning on writing a blog article about UVC disinfection, and will include this bulb as an example of what NOT to buy.
Incidentally, for laughs and giggles I checked it with a UVA/UVB meter and there was zero there as well - so the bulb is emitting zero UV light at all. It's just a pale blue/white visible light bulb.
