"Cruise not available" after 17.17.4
Discussion in 'Model X' started by Lindex, May 10, 2017.
Tags:
  1. Lindex
    Lindex New Member
    SoCal
    My Model X still can't use AP after 17.17.4. ("Cruise not available") Is here anyone having the same issue?
  2. BigMskiman
    BigMskiman Member
    Pleasanton
    What did you upgrade from? And did AP work before?
  3. Lindex
    Lindex New Member
    SoCal
    17.16.45 and AP stopped working after 8.1. I thought 17.17.4 should have fixed "no ap issue" but apparently, it does not fix all the issues.
  4. ab26
    ab26 Member
    Bay Area, CA
    So I had the cruise not available after 8.1 for several weeks. Just prior to 17.17.4, my SC did a remote over the air fix (they called it some kind of a bootloader reset - not all SC is aware of this I believe). AP2 was working fine since then. I installed 17.17.4 and it's still working fine.
    There are reports stating that 17.17.4 fixed the issue, as well as reports that it didn't.
    So it seems like the cause of the "cruise not available" could be several things and this update only fixed stuff partially.
  5. NikeWings
    NikeWings Active Member
    Los Angeles
    It happens to me from time to time, but I am not blocked from using it completely. Are you?
    Mostly available but no consistency to when its not available. It just freaks out and screams at me. :rolleyes:
  6. Lindex
    Lindex New Member
    SoCal
    I can't use AP at all. But sometimes it will show speed limit for few seconds then go away, and sometimes I can use TACC but still only last for few seconds. Before 17.17.4 I don't have AP but TACC worked like 5% of the time. if TACC was available from the start I can use it until next drive.
  7. JoeZ
    JoeZ Member
    Irvine
    17.17.4 did not fix my issue just like op. Few days ago when I was visiting SC for this issue, I mentioned that someone in TMC said resetting boot loader may resolve the issue temporarily. The guy at SC told me "not everything in the forum is correct."
  8. ab26
    ab26 Member
    Bay Area, CA
    Lol, the SC sometimes amazes me! I have got more accurate information from this forum than the SC. Period! As for the over the air fix, this is true. It worked for me as well as few other people in this forum.
  9. vandacca
    vandacca ReActive Member
    Hamilton
    Not sure if resetting the boot loader would do anything to help. However, this sounds like you need to recalibrate your turbo encabulator.
  10. DauntlessDan
    DauntlessDan New Member
    Dallas, TX
    Totally lost my cruise control when I did the chill mode update two weeks ago. I get the 'cruise unavailable' message. Tesla support says they're working on it.
  11. uuxxaa
    uuxxaa Member
    Seattle
    Had the same problem, where I lost all driver assist features including TACC starting with 2017.40, it only came back with 2017.44. What is your version?
