For those of you that own a Blackvue Power Magic B-112 battery, is the power LED supposed to always light up when it is receiving power through the cigarette lighter?
I just received mine today. When I plug it in, the 4 battery LEDs flash once and then stay off. The power LED never turns on. The dashcam, however, which is connected to the battery, turns on and stays on while the car is on. I left the car on for an hour, and the power LED nor the battery LEDs ever turned on. As soon as I turn off the car, the dashcam also turns off.
It sounds like a dead battery to me, but I wanted to make sure this isn't normal behavior until the battery gets enough initial juice?
I have a B-112. When it's on, the left most light will be red. The white lights will sequentially light up from left to right with the right light blinking during charging to show the current battery level. It sounds like yours isn't charging but still supplying pass-through power to the dashcam. Maybe try seeing if it will charge when the cam isn't plugged in. If it does and gets to a full charge, then you could see if it holds the charge.
