Frankman60
The Blackvue DR650GW power input is 12 to 24 volts DC so no voltage reduction should be necessary. Connecting the two power wires directly to the Tesla unused connector inside the microphone grill should be fine, no?
SO, I finished the install and unfortunately had some problems. I connected theNice! I'm looking at this install myself. Any chance you can post a list/links for everything you purchased along with the install steps? I know they're sort of out there already, but it would be great to have a fresh one that I know is current. Good luck with the install!
SMAKN® 12V 5A Female Car Cigar Cigarette Lighter Socket Plug Connector Adapter using the power supply in the microphone area and the StarTech.com FAN4EXT12 12in 4 Pin Fan Power Extension Cable - M/F
Dashcam did not power up, checked with volt meter and get 10.2 volts........a little low but I thought it would still work. Cut the wire and and directly w/o fan connector wired the female socket plug. Still no good and only 10.2 volts. IK the dashcam works because I tested it in the 12V supply. Others have said they used this microphone area wire but mine does not give off enough voltage. I ended up using the power supply behind the rear view mirror ( Plan B ) and it works fine but wires are tough to hide from there. Frustrating!
This is the microphone area wire connected to fan plug. No problems if I had 12 volts View attachment 191675
This is the wire I used behind rear view mirrorView attachment 191676
It works but it was harder to hide the wires:
I like the feature set of the BlackVue and I haven't found a competitor that matches it.I just have a general question that viewers of this thread can probably answer rather than starting a new one. Why is this particular dash cam (BlackVue) so popular with Tesla owners -- reviews on Amazon are quite mixed (overheating issues, longevity, etc)., and it's a premium price. The price shouldn't scare off many Tesla owners but why not go with a more highly-rated cam? What are the specific features that make the BlackVue so appealing?
With the mic grill install for power, are you cutting off the bulky 12V plug of the Blackview and wiring it direct or keeping it intact and stuffing all the wire behind the grill. I remember reading the blackvue had a voltage reduction through the plug and that's why it voids the warranty if it is cut off. Thx.
I bought a cable that had the DC barrel connector compatible with the Blackvue and nothing on the other end. Then I wired the other end to the 4-pin fan connector that I linked earlier. I made the cable about 18 inches long so it is plenty long enough to get from the rearview mirror to the microphone grille, but I don't have a lot of wiring to hide.
Agreed I tested and got the same results when I wired mine, black was ground, one was 10 volt and the other was 12 volt on a refreshed car from JuneThere are 3 wires. (Ground, 10v, and 12v) Use the other wire instead and you should get 12v.
Grey is the 12vJust for the record on this thread, on the refreshed MS what wire color is ground, and what wire color is 12 volts DC on the connector behind the microphone grill?
I have installed the Blackvue on a 2016 refreshed Model S, and yes, the unswitched 12V connector is in the microphone grille. You can get a 4-wire computer fan cable (https://www.amazon.com/gp/product/B0058DN7B8/ref=oh_aui_detailpage_o07_s02?ie=UTF8&psc=1) to mate with the connector for a clean, removable install.
For those that have installed a Blackvue dash cam right behind the mirror on a refreshed MS, is the Blackvue consistently getting a GPS lock?
Seems to be locking in a GPS signal most of the time.For those that have installed a Blackvue dash cam right behind the mirror on a refreshed MS, is the Blackvue consistently getting a GPS lock? I installed the dash cam as high possible behind the rear view mirror and it isn't getting a GPS lock.
Chopr147, it looks like the GPS blue light is lit in the photo you posted of your installation. Is it consistently locking GPS?
There are 3 wires : black (ground), green w/ red stripe (10V) and a grey wire.
Dash Cam | TeslaTap
"The two attached gray connectors are for the microphones and do not have power. "
There is only 1 grey wire but this was the quote
