It isn't for you to decide what this thread is about. The OP made a point that Audi (who put their battery into a car) is failing to consider charging speed as it relates to the thing being charged (a car). So the thread is exactly about comparing cars. And if you look at Audi's own chart, it compares... cars. Not batteries in a test lab.
If you really believe that then we must be reading different forum threads. The title clearly states that we are discussing different charging techniques, not cars. And no, Audi does not compare cars, it compares Audi's choice of charging method vs Tesla's choice. It has nothing to do with each car efficiency and mileage! You can't debunk Audi's claim that sustained power beats top power by insisting that Tesla's cars are more efficient and have better range. These are two separate things.
[QUOTE="SageBrush]You misunderstand my comment. Watts per time has no useful meaning in this discussion.
However, kWh is a useful unit.
Consider a graph that plots power on the Y axis and time on the X axis. The AUC is kWh.
Just eyeball the graph with one line drawn at Y = 150 kW and another line the V3 power output into a Model 3 LR
Can you identify the two congruent triangles ?
[/QUOTE]
Ah, I see what you mean
. Granted, you seem more familiar with various units of works, but that is not the point. I am pretty sure you understood what I mean. We need to find average charging rate or total charging time for comparable batteries and the discussed here added mileage per minute is definitely not doing this. Audi's chart is much more representable for the case.
Also I am not sure I get your point about the chart. The claim is that if you charge with 150kw continuous instead of 250kw peak, it will be able to sustain 150kw for longer, thus achieving faster charging time. Audi claim they are doing just that but their comparison is flawed, because their battery is bigger and they charge it only to about 89%. That's why I said we need comparable batteries to find out whether they are right or not.
[QUOTE="SageBrush]I agree, but @afadeev has asked a tangential question whether a V3 Supercharger set to 150 kW ~ constant would be a faster charging time than the power curve Tesla has chosen. The answer for the Model 3 LR varies from no to hell no depending on start and end SoC.[/QUOTE]
Well, if you charge from 10 to 50%, obviously Audi's way is not better, but I don't think you have the data to claim that for charging to 100%. You don't know all the possible reasons behind the aggressive tampering in Tesla's case and you don't know whether it will be possible to sustain somewhat lower charge rate for longer period of time.
