I think I win for the lowest numbers:
85kwH with v5.6, 11k miles, 90%=218 miles.
I live in Northern California, so I don't believe that weather is causing the lower numbers. Noticed these low numbers since v4.5/4 months. Probably started happening right when I started lowering my charge limit to 60-70%.
they're all hovering around 182, plus or minus 5 to 10 miles depending on how cold it is. The 90% charge is for the most part the same as it was on firmware 4.5. I am however, experiencing major vampire losses now that I did not have before. on 4.5, I would lose approximately 10 miles in 24 hours. On version 5.6, I am losing 10 to 16 miles in 6 to 10 hours. I just got off the phone with Tesla, and they're sending this to the engineers. They are downloading my logs and will return a call to me within a few days.
Any other range-limited 40/60 owners on 5.6 yet? I upgraded last night...my rated range range at full charge was 134 on 4.5 and is now 127 on 5.6. End of June delivery and 5,400 miles. Wondering if there are similar changes being experienced out there.
Just got my upgrade a couple of days ago. Charged to max of 130 on 5.6, when it used to be 134 on 4.5. It also might be due to the extreme cold that fell at the same time I got the update.
Since Tesla top balances their packs, I can't see any way that the 40/60kwh cars are being balanced, especially since the limiting firmware seemed rushed.For the software limited 40kWh cars, how and when will the balancing happen? because the battery never gets full and at most gets charged 67% only on a full charge. Don't they run the risk of getting severely out of balance with no possibility of balancing ?
The good news is that these packs don't get hurt be being out of balance.
Tried a full charge last night for only the second time since I've got the car. With v5.0 I was getting 215. With v5.6 I am now getting 207. Anyone else out there with a 60 kWh pack that has experienced this?
I wish! I'm getting 191-193 rated miles on a full (100%) charge and I'm on 4.5 which should report higher numbers.
Hans, what is the outside temp? And are you charging in a heated garage, or a garage that is for the most part, same as outside temps.
You're lucky you're still at 130. Am curious why mine dropped so much. No cold issues here in Hawaii. And temp range hasn't really changed since summer. Will be interesting to see what other 40/60 owners are getting for rated range after the update.
