For whatever it's worth, I'm also very happy with the retained battery capacity. I don't drive much, but my car is about to hit its 4th birthday in two weeks and my stats are:
Age: 4 years
Miles: 27,000
Rated miles at 100% charge: 260
@David99 - What is your daily charging level % (majority of the time)? If less than 90%, I would be curious to see if 1 week of daily charging to 92~94% might recover some range. I am by no means an expert, but several threads 2+ years ago suggested this helped with battery balancing, which in turn helped increase range. If this worked for you, it would imply the earlier theories were right; if it doesn't work, then maybe aging effects are now dominating. P.S. I have done this myself and have seen improvement: My 90% is 234 and my 100% is 259~260; original 100% was 265 (S85 with 40K miles).
Based on my experience I can say with confidence that balancing is not an issue in any situation.
According to this study MaxRange Tesla Battery Survey my degradation is actually slightly better than the average.
I still feel like my #'s are lower than most people's.... oh well. I guess somebody's gotta be on the lower end of the curve. (story of my life)![]()
Good point... might also be slightly warmer climate overall... which could speed up degradation.. especially when parked and the cooling systems aren't running or the cooling thresholds go higher to preserve battery and reduce the vampireBatteries age with usage but also by time. You car has less miles than mine, but it's a year older.
About the same for my 2015 P85D. 2 years old, 24K miles, 225 at 90% vs. 227. Much better than my 2012 P85.Holding at about 0.5% loss after 33K miles. Was 227 at 90% when new. Now 226 at 90%.
