Deurhendel model 3 blijft hangen
Google Translate of the OP: "My left door handle hangs, doesn't go all the way in anymore. Does anyone have experience with this? It is a mechanical problem, the mechanism is running."
This sounds like a Model S problem, not a Model 3.
If you do have a Model S, it is a well-documented issue, unfortunately. There are a lot of threads in the Model S section of TMC about this exact issue.
Reactions: Phil V
Ook gehad, inspuiten met we 40 op het draaipunt heeft geholpen
As always.
