Did Model S Plaid just have range downgraded by 37 miles?
FIY. In October, i drove my Model S Plaid from 100% to 3% and drove 363 miles. To be honest, the last 12% i drove under the speed limit to see how far I could get and made it to a supercharger. So real mileage would be around 375-ish. It was low 60’s out and was driving speed limit the first 80% of the battery. From West Chester, PA I made it all the way to North Carolina without stopping to charge.
You will likely lose 5% degradation the first year, then loss is much less per year after that. You will also lose 20% to 50% during cold winter driving. Also, the total range for the EPA rating is best contitions not going fast, and running the battery from 100% to 0%, which you would never do in driving Useful range is more like 20% to 80% normally, so that loses 40% off the EPA range right off the bat.
Reactions: zoomer0056
Humble suggestion, if you have a weekend cottage 350 miles away, without knowing the temperature and elevation you will encounter on such a drive, it is worth considering a LR 19" and a 240V outlet at the cottage.
There are plenty of superchargers around. It is around 400 miles to my family, so I really only need to Supercharge once to make it, but only 120v easy access at family destination (I have a mobile charger). I stop at closest supercharger to destination and charge so that I have at least 80% on arrival. Then the 120V will keeo me full until I start the return.
I would at least install a 240v outlet, and maybe another Tesla Wall Connector if I owned another property that I regularly visit. It is sometimes inconvenient, but always available to top up at a Supercharger for infrequent visits.
Reactions: Eric33432
I'd want more detail on that. I've never even hit 300 miles with my plaid.
here is my teslafi data from 10/16/2023. I did not schedule preconditioning of the battery before departure. that would have probably helped with range to get the battery at the most efficient temperature for performing. I tried to hold it in, but had to stop in virginia to use the facilities.
Reactions: byeLT4
