We got the Radian 3R instead. Tight fit with the rear facing maxi cosi but I managed to fit them all in.
Decided against the Foonf because you can't take off the covers to wash.
Yeah you have to use the seatbelt for the middle seat. There aren't any Isofix/LATCH points for that seat.For the folks using the middle seat, you don't use the isofix mounts right?
Resurrecting this old thread since I'm looking for a second car seat. I'd like to do similar to what you did and have a rear-facing seat behind the passenger and a front facing seat in the center, keeping the space behind the driver unoccupied. We currently have a Britax Boulevard front facing in the center and a Britax Infant B-Safe 35 that goes behind the passenger. I'm thinking of getting a Diono Radian for the center and move the Britax to behind the passenger, but don't know if it's going to fit.
Which Maxi-Cosi is that? Is it a Pria 85? I'd like to look up the dimensions to get an idea of it's close to our Britax to see if I can put a Diono next to it.
I love the Britax. We have two of those in the BMW 750. We have the Diono in the Model 3. I don't think you will be able to get three across. The Britax's are too wide. I can try it out if you want.
Not trying to get 3 across, but I guess it's kind of a similar question because I want the Britax and the Diono side-by-side with the Britax facing rear behind the passenger and the Diono facing forward in the center.
I've got the Diono on order, so I'll be able to see for myself soon.
I’ve got 3 across in my car currently. Two britax marathons and a graco tranzitions.
Tony, you wouldn't happen to have a pic of the Graco in rear facing mode in the Model 3 would you? i'm looking to purchase the same car seat but want to see how it looks and the spacing.I had the Radian RXT installed in the rear facing config on the rear passenger side seat. It almost fully obscured my rear passenger window. I ended up moving that seat into my CUV and using a Graco 4 Ever seat in the Model 3.
Thanks McMooTwo radian rxt and a Graco infant seat fit, and I’m 6’2”. It’s a little tight to snap in the infant seat but works. A more narrow infant seat would make fit it slightly better.
Had to run out and move my car so I got the pics for you. Let me know if this is what you were looking for.Tony, you wouldn't happen to have a pic of the Graco in rear facing mode in the Model 3 would you? i'm looking to purchase the same car seat but want to see how it looks and the spacing.
Awesome thx, which Graco seat is this?Had to run out and move my car so I got the pics for you. Let me know if this is what you were looking for.
View attachment 435286 View attachment 435287
Graco 4Ever. It's a steel reinforced frame seat as well.Awesome thx, which Graco seat is this?
I’ve zeroed in on Clek for my TM3 but not on a model.Update as well, both Clek fllo and foonf fit rear facing. It's a tighter squeeze with the foonf rear facing because it's higher due to the base.
The foonf has the ability to recline, though I can't say we actually used it. It has bars that extend and clip rather than dealing belts, making it easier to remove and put back.I’ve zeroed in on Clek for my TM3 but not on a model.
Any recommendation between Foonf and Fllo? I can’t decide and differences seem minor between the two
Also, how easy to put/remove a toddler in/from a rear-facing seat?
Many thanks
