Brass Guy
Preheating the cabin while plugged in will heat the battery if not in range mode. Range mode definitely reduces (if not eliminates) battery heating, plugged in or not.
In my 2013, the battery heater energy use shows up on the dash display. I still have the round gauge center display. With a cold soaked battery, it shows the 6kw use even with climate control off. (Over 10 with cabin heat.) It drops to near nothing when I turn on range mode.
In the past I used range mode to lower my wh/m. If I forgot to turn off range mode, charging would take much longer since the BMS will trickle charge if the battery`s too cold.
The battery heater only seems to heat enough for about 30kw regen, about half the max. Charging always heats the battery, which is why you want to time charging around your departure time. The higher the charge rate, the faster it heats.
If the battery is cold soaked, and range mode is on, it will trickle charge which will take a very long time to heat up.
