croman
Lots of good tips. Those that don't know what cold is -- it got several times below 0F in Chicago last winter and I only exceed 400kwh per mile average once.
The only advice I can add is to try to evenly draw power from the battery (AP is great at this). Don't floor it and then try to regen back as it will be very inefficient at both producing power (sometimes you'll be power limited due to cold as well as regen limited).
Start regen braking far further out than usual. Regen, even if 10kw, will help warm the battery and make your drive more efficient. Since regen will be limited, you'll need more distance to stop but you should be able to capture most of your KE into PE again (and warm the battery in the process).
Consider using the cabin pre-heat from app as it will draw tons of power (6kw for PTC heater!) but if you do it for 15 minutes, you'll only use at most 2kw but it will result in a more efficient drive overall and you'll be happier). Sometimes 2kw makes a big difference on how you feel about losing efficiency in the winter (as in, you'll be warm so you might not care anymore).
My lifetime average after 1 full year (of Chicago weather) is 281wh/mi which is below the rated average. I never use cabin heat when alone but with my child, I use it to take the chill off (and if that's >15 minutes the PTC draw usually drops to 1-2kw so I might keep it on).
Just remember, this isn't even winter yet. You might stop caring about being efficient once it gets truly bitter cold but these things also even out over the year.
