This *is* the one owner refillable thing.... you can use any fluid you like that is normal washer fluid.Is it just my MX or is the washer fluid just water?
I would think they would give you a nicer washer fluid.
Seriously, you can't even get the normal blue bottles at your 'gas' station? Good grief, I thought the paint mess was bad enough!Sorry, welcome to a little taste of California. Extremely strict emissions laws here, you only get the weak detergent based washer fluids here unless it’s winter and you live in a mountainous region.
For everywhere else, you guys get to spray methanol, otherwise known as liquid smog, at your windshields....
Considering your car is delivered to canada, I would personally just spray out all the factory stuff and replace it with local washer fluid.
Especially when it's is the only fluid in the entire car ha
I don't know about spraying it out, I'd suck it out and refill with something that actually cleans the windshield!
Around *here* we get real stuff in the blue bottles (now *I* sound like a moonshiner...)Unless you're near Lake Tahoe up in the mountains, the blue stuff is also fake, detergent based, 32F freezing point (gee it's as if it's water…). In my experience, mixing Einzett concentrate yourself is the best way to get effective washing power. Even then, the labeling says you must dilute it 1:20. Any stronger and it's also illegal.
I would tell you what I usually do with the concentrate, but I can't take the chance that you are an undercover CARB agent ;-)
The first time I got really mad about it was when I was going to Tahoe last year. I tried to stop by every single gas station on the way up the mountain and the first one with methanol blue fluid was after half an hour in the freezing cold and by then my nozzles already were heated shut. Had to survive by pouring washer fluid down the sunroof periodically and wiping it….Around *here* we get real stuff in the blue bottles (now *I* sound like a moonshiner...)
You need to talk to your SC, you have to use a certain fluid do to the windshield coatings. I used the blue stuff from a gas station and they went ballistic on me. They have it a the SC, the kind that they want you to use.
And diff fluid, battery coolant and aircon fluid.What about brake fluid coolant?
