Man, those first 15 pages were tough to get through
Ordered a 4kW + 2 PW system a few days ago. Will be adding this to a home with an existing 4.2kw SunPower system (w/ in-panel micro-inverters). Existing SR MY +
triCT on order (2023??
No where in the order process could I enter information re. existing solar - will need to ping the PM.
Three questions
1. Will this setup work? I want whole house backup and for both solar arrays to feed into the PWs (for both with and without grid power situations).
2. Can a PW+ be used when combining existing + new solar? Is the default now a PW+ Unit?
3. Any reason to consider only 1 PW? Originally I chose two, mainly for the added continuous/surge power - would like to be able to run the a/c if needed. But now with PW+, 1 may be enough? Though the 13.5 kWh may be undersized for a 8.4kw PV (is there a golden ratio of PV kW to #PW folks use?) and or to make it through the night in the event of an outage.
Home is new construction, SDGE territory. 3200sqft. 200A main + sub panel upstairs.
And finally, without a more detailed design, not sure if I want to or need to cancel. Can one cancel further along in the process? I see paperwork that allows for a cancellation only with the first 5 days? (2 days to go for that). But as of now, I have 0 information to make a decision.
