Can anyone here recount the last time they’ve had a blowout on a modern tire?
This just isn’t a thing any more.
<—— 100k miles in a Model S at 45 psi on objectively terrible rural mountain roads
Cold at 45 psi. Summer here reaches over 100 and the psi is way past 50 psi. No blowouts. Our Pacifica asked for 39 psi. Due to elevation I have it cold at 42 psi. Always 3 psi above recommended at Utah elevation.
I would say operational limit. Of course the safety limit is going to be higher than that.50 psi is just the guaranteed safety limit, in reality they can prob go higher, but the manufacturer doesn't want the liability.
When I was a teenager, so I'm not sure about what sense of "modern" that covers. It was a tubeless radial, so design wise modern albeit with materials short of what we have now. But it wasn't the side blowing out. It was the tire tread unfurling, at a speed that shall remain unnamed, and it beat the living crap out of my rear passenger quarter panel as it kicked a huge rooster tail of rubber bits up into the air behind me. At first I thought the hole rear end had blown up or something, until I noticed the rooster tail was to one side.Can anyone here recount the last time they’ve had a blowout on a modern tire?
so is the 45 recommendation @ sea level?
That's why I wouldn't normally set to 50 PSI cold locally here. The hot, direct sun days could easily push that up to 55 PSI without even driving hard. That's getting a bit much, and those high pressures just murder the middle of my treads even at 45 PSI cold.Tire pressure is always referenced vs. atmospheric so 45psi period, BUT if we drive to different elevations the pressure in the tire will "change" just because the atmospheric reference has changed.
Set it where you do most of your driving, don't worry about the variation unless spending weeks at a drastically different elevation.
Why do you increase psi for elevation ?Always 3 psi above recommended at Utah elevation.
It's not due to the weight of the vehicle. Plenty of similarly heavy BMWs and Mercedes use lower air pressure. If it was due to weight, the standard range and mid range models would have different recommended tire inflation values.
Tesla went with 45 PSI to reduce rolling resistance, at the expense of reduced grip and increased road noise.
And plenty of others spec high pressures. Of the cars I own:
2010 BMW 535i M-Sport - 42 PSI
2014 Audi Q7 - 44 PSI Front, 49 PSI rear
2007 Dodge Ram 2500 - 50 PSI front, 70 PSI rear
Last week my Tech asked me if I wanted my tires checked and I say yeah, but I didn't want the standard 45PSI. He had expected my door said 42, and was going to set them at 42. Some Model 3s come with that door sticker instead (seems linked to having 19" rims?).The 535i is comparable, it uses 42 PSI, which is lower than the typical 45 PSI recommendation for RWD Teslas. It's also in a very similar weight class as a Model 3 and has similar tire dimensions. That seems a more reasonable number for our 18" tires.
Yeah, it is mostly treadwear I'm thinking about. Plus you lose some lateral grip, which I regularly use most of. The harder, more "jumpy" ride doesn't bother me, but it could be a factor for some. Very clear trade-off for the range enhancement of driving very firm tires.The max 50psi cold will take extreme use into account, the extra heat of the sun or driving won't cause a failure, there is plenty of safety margin.
Now treadwear will most definitely suffer if at 10psi over recommended.
May be dating myself a bit but I suspect most of us here are middle-aged or beyond. Remember the Ford Explorer/Firestone fiasco? That was Ford's fault for recommending excessively low tire pressure to improve ride quality. Low pressure creates a lot of problems
The door sticker on my AWD with 19” wheels shows 42psi recommended. Tires of course say 51psi. I prefer a cold tire pressure of 48-50psi in cool weather, which is most of the year where I live. (Edit: apologies, don’t know why these photos display upside down, they look correct when viewed on my iPad)He had expected my door said 42, and was going to set them at 42. Some Model 3s come with that door sticker instead (seems linked to having 19" rims?).
The PSI rating stamped on the tire is just the maximum for the tire itself, not an actual "recommended pressure" for the vehicle they are on. Once upon a time you basically never wanted to be close to the tire rating max as handling would be atrocious and it would even impact acceleration characteristics because of poor contact with the road. Modern suspension design has made that much less the case but if you ask a lot of your tires in handling performance then it still matters some to keep lower (but not so low that you run into heating your sidewalls, having the tire roll over on the shoulder when turning, risk popping the seal on the bead, etc).The door sticker on my AWD with 19” wheels shows 42psi recommended. Tires of course say 51psi. I prefer a cold tire pressure of 48-50psi in cool weather, which is most of the year where I live. (Edit: apologies, don’t know why these photos display upside down, they look correct when viewed on my iPad)
