JRP3
Hyperactive Member
Yes they must have some buffer at the top and bottom. One of the big problems with going to zero SOC is that the cells are probably top balanced. Finishing charge voltage is used to balance the cells when full, since cells are of slightly different capacity that means they are unbalanced at the bottom. Think of lining up a bunch of sticks of different lengths, you can line them up so they are all even at the top but they are uneven at the bottom, and vice versa. Top balance means on a deep discharge some cells end up closer to zero than others, and if a few hit zero under load they go into reversal and are ruined. Since I'm not using a BMS on the pack I chose to bottom balance my cells, so they all discharge to the same SOC level and even a deep discharge can't drive any single cell to zero and reversal under load. I leave a little more room on the top and stop charging early to compensate, giving up a couple miles of range.
