While commuting, I wonder if I should simply use autopilot to save more battery. What do you guys think? Assuming you are driving almost same speed and other conditions are same.
I agree. There are times when you can tell a light is red or there's a stop sign whereas the ICE car in front of you will do a rapid deceleration. If you don't have someone right behind you, you can really just coast to the same spot whereas autopilot will be less inclined to begin a slow deceleration, as you already know the light or sign is there whereas autopilot doesn't. This is where you can significantly perform well with regenerative breaking on your own. Also deceleration while going downhill as opposed to maintaining a constant speed. This may all change when the car starts recognizing street lights and stop signs.It's pretty much the same as a human, though if you're careful i bet a human driver can beat autopilot as we can be slightly smoother with braking/acceleration which is always more efficient - but it's going to be very similar.
Hypermiling involves adjusting your driving techniques to maximize the battery efficiency (essentially get the best KWH efficiency possible) by either modifying the car, driving a certain way, or both. Assume, for instance, that you were driving on a steep downward incline for an hour. Theoretically, you would have achieved efficiency well over the rated miles per KWH if you let the car coast down the incline. This is because the car is capable of regenerating some power when there is forward momentum greater than current acceleration. This is that concept. There is a guy who drove 606 miles on a single charge. But I think this was done on a closed circuit or just by going around in circles really slow or something. Essentially, you could hypermile by limiting your acceleration, and driving really slow or at a variable rate of speed. Some common changes are also actually switching to aero wheels while still lowering the suspension (Performance model). Folding or removing the side mirrors since mirrors produce 10% drag through air. That kind of thing. But for most of us normal people, it just involves driving conservatively and not slamming the accelerator much or even using the actual breaks much.Does things like not using phone key disabling auto power off save energy? What is Hypermiler? I just would like to save unnecessary consumption of energy. HVAC is turned off and used only as needed. Paying attention to sudden acceleration perhaps helps. I am trying to figure out if there is way to measure how efficiently I drove.
Depends on the car, the route, the temperature.I seem to get 200 Wh/mi for my 20+ mile commute. Does this seem reasonable?
