...disconnecting the negative battery terminal
What about trying a positive terminal disconnect too?
Wouldn’t matter. Disconnecting either terminal prevents current flow, isolating the battery. But, the car seems to realize the 12V battery is “gone” and compensates.
If the car is in a secure location, what happens if you disable remote access and power the car down fully using the power down button on the screen?
If you plan to store your 3 for several weeks in a garage with no electrical outlet, can you just disconnect the 12V to prevent any significant battery vampire drain?
Last time I did that I came back and the car was dead -4%. Had to jump it from an ICE and run a 120V cable into the terminal while illegally parked for 4 hours, then charged overnight at a hotel before driving home 40 miles. Not a great experience.3 weeks is not that long. Just charge it to 80% and forget about it.
So "charge it to 80% and forget about it" is a dumbassed idea. I need a real solution.
