ACarneiro
Sorry, I didn’t quite follow. Tell him what?Tell that to my brother in North Carolina.
I’m not saying it doesn’t happen, just saying it seems uncommon.
ahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahaI would imagine it may be because the motorways are infinitely better looked after
I’m glad I amused you, but that’s my experience…ahahahahahahahahahahahahahahahahahahahahahahahahahahahahahaha
Had me rolling on the floor there! Good one!
See the reply from @M1tch -- he puts it perfectly. Not having a dig at you and I generally find your posts helpful and thoughtful. But the notion that the motorways (highways) in the USA are "infinitely better looked after" just isn't true. Sadly.Sorry, I didn’t quite follow. Tell him what?
Oh, I see where the misunderstanding is.See the reply from @M1tch -- he puts it perfectly. Not having a dig at you and I generally find your posts helpful and thoughtful. But the notion that the motorways (highways) in the USA are "infinitely better looked after" just isn't true. Sadly.
The difference with the Tesla is that the remote defrost heats up to an EXTREME level, much hotter than using the defrost at the maximum level on a ga- engine car. You would think that the Tesla software would be able to gradually increase the heat on a cold day to avoid cracking the windshield. After 45 years of driving, with much experience in cold northern New England, I have never had this issue before, although my windshields on other cars had been through many more stone impacts. I think this should definitely have been covered by warranty, and am extremely disappointed with Tesla.Windscreens do typically do crack under extremes of temperature such as being very cold on the outside and hot on the inside due to the thermal stress but only if there is a fault in the glass that acts as a weak spot. If not then this would happen all the time.
The only question is really was it a stone chip or a fault in the glass. Tesla clearly giving themselves the benefit of the doubt on this one not surprisingly.
I do though sometimes think EV's are more prone to this. An ICE when defrosting typically has a cold engine so the air used to defrost is not very warm so there is less thermal shock than with an EV that is able to blow very hot air almost instantly.
Similar thing happened to me in reverse. Hot sun on a cold windscreen. I was able to trace the crack back to what was clearly a stone chip.
Here in the UK our insurance policies typically cover windscreens with a very low excess, deductible I think you would call it. So mine was replace for less than $150 fortunately.
I just picked up my Y with the new windshield, and spoke to the service manager about my annoyance about this. He immediately reversed the first service rep who claimed this was not covered by the warranty, and replaced my $1500 invoice with a $0 charge. Perhaps the first service rep who claimed invisible dings in the glass caused the crack came from one of the smarmy non-Tesla dealerships I have dealt with for my former cars.
Now it makes sense. Your posts are helpful and wasn’t having dig I just find our roads utterly abominable. “Maintained” by the highways wombles that just install cameras, new crash barriers (that aren’t needed) and they rebrand every few weeks as they are so rich. Just a horrendous money pit.Oh, I see where the misunderstanding is.
“Home” is in Portugal. I have never driven in the USA so have no idea of the state of motorways there.
And thank you for the kind words, I do appreciate them
EDIT: having re-read my post I did indeed neglect to mention where “home” is.
Odd, could have sworn I had when I made that post. Brain fart, I apologise.
I am trying to set up something similar but getting stuck - do you have your shortcut file or link? that I can modify as I need to set up time and also days I don’t want it to precondition at that time?As a rule of thumb I created an Apple Shortcuts automation based on a couple months of trial and error in the winter:
In the morning, when > 10° -> do nothing
When > -2°C -> Precondition
When <= -2°C -> Precondition AND Defrost
One of the main road near me is being resurfaced at the moment. It improved dramatically when they removed the old surface (eliminating all the potholes). Now the new surface is going down and it’s anything but flat. Why, in the days of laser levels, GPS, computing and sensors on anything that moves, can’t they lay a flat bit of tarmac?Now it makes sense. Your posts are helpful and wasn’t having dig I just find our roads utterly abominable. “Maintained” by the highways wombles that just install cameras, new crash barriers (that aren’t needed) and they rebrand every few weeks as they are so rich. Just a horrendous money pit.
Glad your roads are good though and thanks for all the other help since I’ve been on here
Is that being done with the HS2 money?One of the main road near me is being resurfaced at the moment. It improved dramatically when they removed the old surface (eliminating all the potholes). Now the new surface is going down and it’s anything but flat. Why, in the days of laser levels, GPS, computing and sensors on anything that moves, can’t they lay a flat bit of tarmac?
Because it’s done as quickly and cheaply as possible after is contracted, sub-contracted, sub-contracted and then farmed out again. And everyone in the chain gets their cut of money so nobody actually cares anymore.One of the main road near me is being resurfaced at the moment. It improved dramatically when they removed the old surface (eliminating all the potholes). Now the new surface is going down and it’s anything but flat. Why, in the days of laser levels, GPS, computing and sensors on anything that moves, can’t they lay a flat bit of tarmac?
I live in Shrewsbury and have been in the UK for over 20 years.Just in case useful:
I'm on PC (not phone) and what I see is that you are in Shrewsbury ... but the LOCATION visible is so short that if you put an explanation of "HERE but sometimes THERE" I wouldn't see it ... although if you are not in Shrewsbury any more? you could change that
Anything that puts thermal stress on the glass i.e. significantly different temperatures on one side or the other makes it more likely to crack but it is only going to happen if there is a stone chip or other fault in the glass.Really interesting, hadn't thought of the reverse shock.
Two of my family members back home have Teslas and obviously cool the car before starting a journey in the Summer.
Cabin temperatures can be in excess of 60 degrees and so far neither of them has ever had a windscreen cracked (he says, jinxing them).
I would imagine it may be because the motorways are infinitely better looked after and it's a rarity to get a stone chip hitting the windscreen.
Here you areI am trying to set up something similar but getting stuck - do you have your shortcut file or link? that I can modify as I need to set up time and also days I don’t want it to precondition at that time?
Thanks, I’ll play around and see what works for me.Here you are
View attachment 1012674View attachment 1012675
It's actually launched through another Automation I have that use Tessie and checks that I'm at the same location as my car in the mornings.
If you have an irregular schedule, you can add a prompt before to avoid triggering the precondition if you're not going to use the car one morning.
