So I can't fault you for this logic (as indeed 14-50 is extremely popular), however, if I look into my crystal ball, the future is that all vehicles are electric and so the commodity builders and mainstream buyers are going to force inefficiencies out of EV charging. The Neutral line is a complete waste for EV charging. So while 14-50 is the most popular today, I see that going away (replaced by hard-wired units or units connected with 6-50 or other receptacle types).
Here is the thing about 120/240v split phase residential service in the USA. If you want 240v, you connect from "hot to hot" and you don't need a neutral line. If you connect a 120v load you go from neutral to hot. If you connect another equal size 120v load you would do it from the other hot to the same neutral. The load on that neutral wire would then be zero. So there is no way to get additional capacity out of having that third wire, if there is load on it, that means one of the hot wires is not being used to its fullest potential. It really is a waste.
So if you just run two conductors (plus a ground of course) to a location for EV charging you would just run both as "hots" and use 240v (which ALL EV's support). If for some reason you REALLY wanted a 120v charging solution, you could use one of the conductors as a neutral and the other as a hot.
Anyway, moral of the story: My prediction is that running three conductors to EV charging stations is going to stop happening... As others pointed out, 14-50 was only popular because Tesla included adapters with the cars by default and it is used by RV's so there were a lot out there in the wild and the receptacles were readily available.
