Don't kill grandma!!!
Discussion in 'Model S: Interior & Exterior' started by chuckd, Apr 4, 2015.
  1. chuckd
    chuckd Member
    Norman, OK
    We've had our Model S for a week now, and this might be a stupid question, but here's the scenario:
    Let's say we're in Phoenix in the heat of summer, and I drive my grandma to the store. She wants to stay in the car in the air conditioning while I run in and grab a few things. I leave the key in the car, but when I jump out the car shuts down, turning off the climate. Grandma's dead in 5 minutes!
    So, how do I 'run in to the store' while leaving the air conditioning running for somebody who wants to wait behind in the car? I hope I don't have to do that with the app, because that's kind of a pain.
  2. MikeC
    MikeC Active Member
    Los Angeles
    I think you could either teach her to tap the touchscreen or don't shut the door completely.
  3. Johan
    Johan Took a TSLA bear test. Came back negative.
    Drammen, Norway
    Good advice Mike.
    I'd close the door, then as I leave double click the fob (like manually opening) to prevent walk-away auto lock. Otherwise the alarm will go off.
    Then she just touches the screen. Maybe every 10-15 mins (?) to keep the car awake.
    You're golden.
  4. reddy
    reddy Member
    Amarillo, TX
    You can also use your iPhone app to turn on the climate control in the off chance Grandma falls asleep and forgets to tap on the screen.
    Also, you can see if the climate control is off or on, and if Grandma is playing with the temp settings again.
  5. Johan
    Drammen, Norway
    Also you could mess with the temp settings from the app :)
  6. ATC@LWSK
    Skopje, Macedonia/Abu Dhabi, UAE/Toronto, Canada
    Or you could have her seat in the driver's seat. Also, write to TM and request a grandma-mode.
  7. Johan
    Drammen, Norway
    Yup. Aggressive throttle mapping. Grandma has weak calfs.
  8. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    tapping the touchscreen turns the car back on...
    otherwise you could put the car in neutral and put the parking brake on. I do that all the time. it will leave the car on indefinitely.
  9. Rheazombi
    Rheazombi Member
    Boston
    Also if someone is in the passengers seat and forgets to tap the screen in time, they can press the driver's seat with their hand and the screen will turn back on. The keys do not need to be in the car.
  10. Krugerrand
    Krugerrand Well-Known Member
    I think Grandma would prefer staying at home in her comfy rocker. Surely you can go to the store and pick up the things she wants without supervision?
  11. yobigd20
    Skaneateles, NY
    just teach grandma how to shop online. I get everything delivered. Even groceries. I only need to leave my house to fill up CO2 tanks for my soda stream but I may go out and buy a huge one and a regulator to fill them up at home too haha
  12. Johan
    Drammen, Norway
    Aren't you doing like 200 miles per day of commuting?
  13. Brit4864
    Brit4864 Member
    South Florida
    As told to me by Tesla in CA. If you leave the drivers seat belt plugged in the car won't shutoff. Never tried that but it's supposed to work.
  14. Johan
    Drammen, Norway
    Nope. Requires weight on the seat.
  15. caddieo
    caddieo Member
    Palm Coast, FL
    I like this! Thank you!
  16. Phil K
    Phil K Member
    Hong Kong
    The simplest way without grandma doing anything is shift to neutral and engage E-brake from the touch screen.
  17. gavine
    gavine Petrol Head turned EV Enthusiast
    Southern New Jersey
    Plus you can lock the door with the fob. If you manually turn the lights off though, they won't come back on automatically when you put it in drive.
  18. mknox
    mknox Well-Known Member
    Toronto, ON
  19. msteinbeck
    msteinbeck Member
    California, United States
    Grandma Mode. Haha. There also needs to be doggie mode.
  20. lorih
    lorih Member
    Awesome!
