I originally posted this on Reddit but I realised it might make more sense to be here since it might be a AU specific thing:
tl;dr - 2019 RHD M3P driver side headlight level eventually lowers even after intentionally aiming it higher than passenger side one - why?
I've noticed this for a while and I wanted to see if it's just my car.
I have a 2019 Model 3P (RHD in Australia) with non-matrix (original) headlights and basically from the start of ownership (I am original owner) I've noticed that the driver side headlight is aimed lower than the passenger side one. It's not slightly lower, its much much lower, the cars in front will see one headlight brighter than the other (I asked a friend to check).
I thought this might be normal to not blind oncoming traffic. However, I've reviewed the headlight adjustment instructions in the service manual (the one you can access for free from Tesla) and the instructions make it clear that both headlights should be level with each other. So as a result I opened the headlight adjustment setting and moved the driver side headlight up a few notches to be level with the other one.
Fast forward 2-3 weeks and the driver side headlight is visibly lower than the passenger one again. It's easy for me to notice because I drive practically the same route every week and park in the same underground parking spot, which conveniently has horizontal lines on the wall.
As a test, I went ahead and purposely made the driver side headlight much higher than the passenger one. Sure enough, after 3 weeks of driving the driver side headlight is much lower than the other one again. The headlight level doesn't just drop on week 3, throughout the 3 week period I can see it get lower and lower.
This is leading me to two possibilities:
Other notes: I am aware that the headlights adjust slightly when you park on an incline and open/close the door, I see this behaviour often on my car and IMO it's a bug. I'm adding this note here to highlight that I think my issue is slightly different and arguably worse.
- The driver side headlight should be this much lower and the car's software has some auto calibration function that eventually lowers it. But this seems counter to what the service manual suggests.
- OR my driver side headlight is defective, something is loose and over a few weeks of driving the headlight level drops.
