If you are on 2017.44 and later, you should see a tick box under your driver's profile reading "Use Easy Entry".Is this only in newer vehicles or is this available in older cars? I have an AP1 P85D that was built in Dec 2014.
I haven’t been able to make “easy entry” work on my new MS 75D. I have a suspicion the secret is in the lock settings. Has anyone figured this out? Thanks for the help.
That worked, thank you!Easy Entry is simply another driver profile that becomes current when you a) have it selected as the option in your driver profile and b) you put the car in park
Do this... put the car in park, observe that the easy entry profile is selected, now move the seat and steering wheel to where you want for entry and exit of the car, save that to the easy entry profile. Now when you enter the car, operate the brake pedal and the car will move to your profile.
There is only one easy entry profile so pick a seat position and steering wheel position that works for all drivers.
It's better to have minimal adjustments, otherwise the process takes too long. For instance, if you have the steering wheel move in and out and also up and down, you will be waiting a while. Up/down has to wait for in/out to finish its movement. Same with the seat. Either do up/down or in/out, but not both, unless you are extremely patient.
Does anyone know how to reset the easy entry settings and have it match the driver profile settings?
