Zzzz...
I'm not sure this is true. What is wrong with springed loop that car push down when drive over it? But!!! Ok. Lets assume you are correct. There are absolutely nothing wrong with "nose" design. And we could position inductive loops as close as we wish. So this is not a problem at all.A vehicle will never get closer than about 4-5" from an inductive loop in the ground.
Won't be high powered. More power -> bigger inductive loops.
It is high power! It is 3kW charger. More than enough for absolute majority of chargings. Avr person drive around 12k miles a year. Lets assume car drives home only 300 times a year. That leave us with 40 miles charging on average per charging. 3kW for 10 hours would add 30 kWh. Heavy and less efficient than S Model X lets assume would require 400 Wh/mile. Notice all very conservative estimates. So MX would recharge for ~75 miles. More than average 40 miles needed. In reality with 3kW wireless charger person in Model X would go for months and months without need to plugin.
And the best part: coil radius is less than 2 inches! Not much metal there. And it already shown to have overall efficiency of 95%.
And the guys who did it did not had multimillion R&D budget. Sure with a little bit of $$$ invested higher efficiencies would be easily achievable. There are talks about 97% for example. And even that is not a ceiling. The wireless charging should be compared with wired, and wired have got it own losses. With integration of wireless subsystem some of those losses could be avoided. Why Not A Wire? The case for wireless power - Wireless Power Consortium
It is an emerging tech. And a lot should be invested into developing of the tech. But even as is wireless charging is very much comparable to wired one in terms of efficiency. Do not forget - that Toshiba device is tiny! Making it 95% efficient was a hard task. With moving to 2 inch automotive coils gaining efficiency is much easier. And there are talks about wireless charging being as efficient as wired one...
