Yes, model 3
@mociaf9. I'm not sure my start/stop odometer for September, but from July 7 - now, but we are at 7,769 currently. Subtracting ~2.5 weeks we were without the car, 2,350 might be a bit low, could be closer to 2,500. Or a straight average over the 3 months is 2,589. We have only charged at home so far, no external charging.
We just dropped it off at the body shop yesterday so I can't check our average Wh/mi but 242 doesn't sound inaccurate. To be honest, I am still having a hard time grasping how to calculate the equivalent to gas as you've done :/ however that calculation makes me feel a bit better.
I can't 100% attribute the increase to the Tesla YoY because working from home more often means running the A/C more often, but September experienced almost no/minimal A/C during the weekday so that should the closest of the last 3 months to an exact YoY. But the increase is nearly consistent through the three months. October's usage should be pretty evident as well. I had been considering getting one of those power monitors that tracks devices' consumption in the home so I can say definitively, but not sure if I want it yet.
Make sure you're looking at the entire rate - transmission + distribution + generation (aka "energy service"). You only get to pick the supplier for generation. Transmission and distribution ("T&D") is your local "poles and wires" company; you're stuck with the monopoly company in your area.
I don't know of anyone doing TOU rates for generation in NH (probably because few TOU meters are in use). If you're in Eversource turf, your choices in NH are rates R (standard residential, no TOU) and R-OTOD (residential TOU).
For R, T&D totals $0.087/kWh. For R-OTOD, off-peak T&D is $0.038, on-peak T&D is $0.175/kWh. Add $0.094/kWh for generation (default service) to get your total $/kWh (R - $0.181, R-OTOD off-peak - $0.132, R-OTOD on-peak - $0.269).
R-OTOD off-peak saves you $0.049/kWh over rate R, but the monthly charge increases to $29.47 from $12.69. You need to use 350kWh off peak, with no peak usage to break even. For every peak kWh, you need 1.5-2 off-peak to compensate.
Because of the limited off-peak savings and high on-peak charge, It's tough to make R-OTOD work unless you can really restrict peak usage and shift a lot to off-peak.
Eversource tariff -
https://www.eversource.com/content/...riffs/electric-delivery-service-tariff-nh.pdf
Thanks, I had been taking into account and comparing the entire rate but after looking at the different supplier rates on puc.nh.gov, their rates were higher than Eversource or required contracts and, to your point, would still be paying for the distribution through Eversource. The switch didn't seem worth it.
Let's 1157 (Sep '18) - 408 (Sep '17) on the assumption that the increase is due to the Tesla which can just be charged evenings/weekends.
Using your rates, I get $98.87 + $109.75 + $29.47 = $238.09.
Current rates listed here indicate R - OTOD on is .123 (.22 total) and R-OTOD off - .081 (.175 total) = $89.76+$131.08+$29.47= $250.31, I'm not sure if my calculations are correct but at either rate, it would 100% not be worth it considering our regular rate bill was $223. This is very surprising that 2/3 of my energy use occurring during off-peak hours would not be enough to justify the switch, and also very surprising that there is not more of a push by electric providers to move to off-peak :/
^Did this/leaving in case any else searches for/is interested in this.
I guess someday down the road solar, or an energy provider that utilizes solar, is the only meaningful way to lower both my bill and my demand.
