I'd been contemplating switching from E-TOU-C to the new E-ELEC rate, they and E-1 were roughly a wash after factoring $180 in additional fixed charges on E-ELEC. But I'm always suspicious when they float a new rate plan with low off-peak rates, and sure enough, E-ELEC is rapidly becoming the new EV-2A - i.e. entice them with a low off-peak rate, and then once you've hooked them in, jack up the off-peak rate faster than other plans.... (By applying the same absolute $ increase evenly across all TOU periods, they are increasing the off-peak rates by a far higher percentage than the peak rates.)
There's a reason they don't let NEM2/3 choose E-TOU-C, so I shouldn't easily let E-TOU-C go (on NEM1), like I stupidly left E-6 a few years back. And indeed, although E-TOU-C looks like it got an absolute $0.01 additional increase vs other plans, they did also increase the baseline credit by about $0.01 as well (have no idea why they define it as a baseline credit, rather than calling it Tier-1). So the actual % increases on E-TOU-C are closer to 13-17%, rather than 15-19% - so long as you are able to keep consumption within baseline (which many solar customers can do)....
