Ok, I went back and did a lot of data lookups. For this analysis I crunched 2 months of power usage data (Juli and January) and I looked at our daily usage pattern. The bottom line is that the Powerwall would allow us to go off-grid for about 8-9 months of the year resulting in significant cost savings.
I also looked at our daytime vs. nighttime consumption and found that we never exceed 7 kWh of nighttime usage, typical number is about 4 kWh. So the Powerwall has the capacity to shift enough solar power from midday to the night. Basically we can cover all of our power needs with solar because of the Powerwall.
And now for the numbers. First up daytime power consumption vs nighttime. In this context daytime means sunrise to sunset.
Representing summer:
5th of May: daytime: 6.48 kWh, nighttime: 3.18 kWh.
And in the winter corner:
5th of January: daytime: 6.37 kWh, nighttime: 6.28 kWh.
I chose these days as examples because they were worst-case within that particular month. It is clear that we would never exceed the amount of power that the Powerwall can provide. Also I was unable to find a single instance of our house drawing more than 1,05 kWh of power at any one hour. So the 2 kW specification + 3kW peak is well within what would be needed.
I used a small 4.32 kWp solar-array as an example. This is the kind of array that would fit on our small roof. We could probably fit a 6 kWp array but that would just make all the numbers even better
Next up is savings pr. month. In the summer would be around $160 in electricity, 30-40% of that comes from the powerwall shifting the power resulting in powerwall savings of about $56 pr month in summer. In the wintertime the savings are $8 pr month. On average we are looking at around $33 pr month in savings from powershifting. Multiply up to a year and we have about $400 pr year in savings from the powerwall alone and it pays for itself in ~8 years. Basically it will be under warranty the whole time and if you buy the extended warranty you should be good for another 10 years.
This is all based on current prices for electricity and the price is expected to go up over the next 10 years and the payout from selling power to the grid is expected to fall about 50-60%. At that point the powerwall becomes a complete no-brainer here.
I simulated expected changes to power-pricing and the monthly saving went up to $50 per month for the powerwall , now it would pay for itself in 5 years.
In closing here are some stats:
January:
Total power used: 362 kWh.
Solar power generated: 72.9 kWh.
Max daily usage: 17
Min daily usage: 7
July:
Total power used: 265 kWh
Solar power generated: 576 kWh
Max daily usage: 14 kWh
Min daily usage: 4 kWh.
Now I'm off to figure what is so power hungry in our house, 17 kWh is just embarrassing. Watch out, something is about to get turned off for good.
PS. If anybody wants a copy of my spreadsheet let me know. Most of it is in danish, you have been warned
