Haha, I am dedicated to the cause, but also lazy.
So I use the itanywhere.no site where we have the S and X delivery tracker. Not sure how they pull the data, but it is refreshing "real time" almost, so they must have a connection to the government registration database. This
is the S and this
is the X tracker.
It`s not too user friendly for exporting, but I just do a "select all" on the site, copy/paste it into Excel, delete what I don`t need and work with that. You can try and select only the data you need for the specific period by highlighting only those lines in the table, but frankly it is a little tedious so I just select all.
One note, if you want to work with this using a non-English Excel: mine, set to Hungarian, can`t really work with the date format (dd.mm.yyyy) they use, so if you try and sort by that it won`t do it properly. We Hungarians normally use yyyy.mm.dd - you`d think Excel would recognize all popular date formats... but no. So I actually split the date field with "data to columns" using the dot as a separator and then sort.
PS, once the month is over I`ll post another slice of this data to the General Discussion thread. You can actually pull what Models were delivered, so those who normally try and work out the revenue/profit based on the delivery numbers could get an idea of X100D vs X75D for instance. I know it`s only 1 country, but it`s exactly 1 country more than we normally have.
