ExtendView Side Mirrors -- outstanding visibility
Discussion in 'Roadster' started by ecarfan, Oct 20, 2014.
Tags:
  1. shrink
    shrink Supporting Member
    Phoenix, AZ
    Okay, just got back from a quick spin during lunch. Daylight helps a great deal adjusting to these mirrors, but I think I'm having an issue with my eyes. To me, the view is still a bit blurry in the outer curved portion, but when I use only one eye the view is absolutely outstanding. Felt like I could see everything and I was much more confident changing lanes on the driver's side.
    I'll discuss with my optometrist, but if you don't have some apparent vision issues like me, these mirrors are GREAT!
    Unfortunately, if my vision doesn't let me tolerate these after a few days, I might have to list them for sale. Will keep you all posted.
  2. shrink
    Phoenix, AZ
    Well, I am sad to say my astigmatism and these mirrors do not agree. I had to pull them off last night. Unfortunately, I broke the passenger mirror during removal, but the driver's side is intact.
    Another member already contacted me, and I'm planning on just donating the intact driver's side mirror for the cost of shipping to another fellow Roadster owner. Hopefully someone can try it out for cheap and before buying a full set.
  3. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    @shrink, sorry to hear that the mirrors didn't work out for you due to your astigmatism. I am nearsighted but not astigmatic.
  4. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I think the trick with these mirrors is to not stare at them, but rather just to glance at them. You really just need to know if there's a car there (or other obstacle). Staring at them makes your eyes go crossed.
  5. bart513
    bart513 Active Member
    East Hampton
    Is there a way to install them that makes it easier to remove in case of shrinkitis? I ordered a pair and have a bit of astigmatism, not much, and don't want to ruin the OEM mirrors:(
  6. wiztecy
    wiztecy Active Member
    Use dental floss or a thin wire behind the mirror to rip the double-sided tape, then carefully pull the mirror away. If there feels like there's tension, run the floss behind it again.
  7. bart513
    East Hampton
    Great idea. Thanks so much!! Damn you are always so helpful D.
  8. Panicopticon
    Panicopticon Member
    Syracuse, NY, USA
    Isopropyl (rubbing) alcohol is a good bet too, typically will weaken adhesives and won't harm the paint.
  9. Roadrunner13
    Roadrunner13 Member
    Montreal
    #29 Roadrunner13, Nov 6, 2014
    So mine have been installed for about a week now...and I like them a lot.
    They don't stick out much...
    In traffic they are really greatl!!! :cool:
    As Doug mentions, the hard part is if you have to stare at them for long.
    For me, that is when I backup into the garage since it's quite tight.
    That's the only time when I'd rather have the originals...but I'll suffer through that for the traffic benefits!
  10. ecarfan
    San Mateo, CA
    Roadrunner, glad you like them. I'm loving mine, really gives me confidence when changing lanes on the highway.
  11. Doug_G
    Ottawa, Canada
    That was one advantage of the multivex - they're curved in two directions so they almost look flat at the edges. But still, you have at least 95% of the advantages there.
  12. Timothy
    Timothy Driving on Sunshine
    I have had my new mirrors on for a week now. Takes a little getting used to, but it does help. Even so, I wouldn't have the guts to make a lane change with just looking in the mirrors. Still think a quick little peak over the shoulder adds to a safer lane change!
    I previously had a stick on small round mirror on the right side. I like this solution better than previously.
  13. bart513
    East Hampton
    I purchased the side view mirrors but am still a bit hesitant to install them... After learning how to "really" place the drivers side view mirror so that you see the cars to the right of you in the side view mirror until they actually are in sight next to you has been a tremendous help.
  14. ecarfan
    San Mateo, CA
    I initially had the same hesitancy after I installed the ExtendView mirrors but after a month I gained so much confidence in the mirrors that I now change lanes without turning my head to look over my shoulder. The mirrors are amazing. You just have to concentrate and understand the view they are presenting. They will clearly show cars that are directly adjacent to you when you can also see the car out of the corner of your eye without turning your head.
    However, I do not have the same confidence in them at night because it is harder to ascertain the position of cars near me at night when using the mirrors, or any mirror, since the lane lines cannot be clearly visualized. So at night I turn my head to check first before changing lanes. But I still think the ExtendView mirrors are great!
  15. bart513
    East Hampton
    Thank you for the encouragement:)
  16. Jaff
    Jaff Active Member
    Grimsby, Canada
    I took mine off last weekend...just could not get used to them + the fact that the made slow speed reversing (between buildings) into the tight parking spot behind my office incredibly difficult.
  17. tvuolo
    tvuolo Supporting Member
    Colorado
    Slightly off topic, but is there a trick to adjusting the mirrors out wider? I can't seem to adjust them to where the side of the car doesn't take up half of the mirror.
  18. ecarfan
    San Mateo, CA
    I easily adjusted mine so that I can only see the side of my car if I lean just slightly towards the mirror. Push firmly on the mirror enclosure. It does not move much when gently pushed on.
    I actually prefer them positioned so I just see the side of the car without leaning towards the mirror. The field of view is so wide that even in that position they will clearly show the nose of a car next to me when it is up to the seat back.
  19. ViperDoc
    ViperDoc Roadster 1305
    Vermont
    Mirrors
    After reading this thread, I got a pair of the Extend View mirrors. I love them! Easily installed and eliminates my blind spots.
    Thanks to those who reviewed this product for the idea!
    David
  20. wiztecy
    I found this stick on convex mirror that fits perfectly with the outside curves of the Roadster's mirror and gives very good range of visibility. I picked it up at Winchester Auto Parts, store may not exist else-where. But its a nice alternative for about $3-$4.
    The way I have my mirrors setup, the very inside of the mirror shows just the outside edge of the roadster so I get a larger road coverage with the plain mirror. The convex is my "check" mirror, that I always verify against before I engage and during my lane change or pass.
