I had 198V at a chargepoint station yesterday with full amperage (30A) yesterday with no degradation from the car for three hours in San Jose.
The software may actually be doing that. I suspect the software probably does detect the nominal voltage when you first plug in; otherwise, how could you charge at 208 or 120 V? If the voltage is low, such at Lloyd's location, but doesn't fluctuate, then you're good to go.I think they've got algorithm problems. My suspicion is it has fixed voltage limits. There's clear evidence for this. There's a particular CS-90 that I've used, which has the lowest voltage I've seen anywhere. I've been told it now always backs down 25%. My office charger is on the low side, and it backs down about half the time. I recently charged on a CS-90 with > 235 volts and it never backed down at all. So it's pretty clear there's a fixed threshold. Bad design.
The grid is a major source of voltage variation. I've observed it at my office - significant changes in a fairly short time period, and it clearly wasn't our load doing it because we don't really have that much (no car plugged in at the time).
You can't have fixed limits - it simply doesn't work. What it SHOULD do is record the nominal open circuit voltage when it first connects. It should then calculate a threshold voltage below that point, where it is going to trigger the back-off.
If your voltage drop is high when the car first starts to charge due to high resistance in the circuit, you're already closer to the lower limit that the software calculates. ie, if the cut-off voltage drop is 5% of initial voltage and you start with a 4% drop, it might only take a small sag on the grid to drop you under the limit. Out here on the farm I typically see a 3% swing in voltage every day at a sampling rate of once a minute. I suspect the swing would be even higher with a very rapid sampling rate that would catch the sags and spikes of large inductive loads switching on and off. Just wait until airconditioning season sets in!
