You will need an HPWC to get the full 48 Amps of charging. To meet code and avoid tripping the breaker, the breaker has to be 125% or more of the continuous load, or the load has to be no more than 80% of the breaker rating
(same numbers, different view). That means that you need a 60 Amp circuit for 48 Amp charging.
The problem is that the currently offered version of the HPWC does not have a DIP switch setting for a 60 Amp Breaker, 48 Amp Charging. Until Tesla offers a 60/48 option, you will have to put in an 80 Amp circuit that can support up to 64 Amp charging (80/64) with appropriately sized wire. The HPWC will then offer 64 Amps of charging to the Tesla and your Model X will use all it can, or 48 Amps.
See page 16 of
https://www.teslamotors.com/sites/default/files/pdfs/tesla-wall-connector-installation-80A-12A.pdf for reference.
Hopefully, with the 48 and 72 Amp charging choices offered for the Model X, Tesla will soon offer HPWC's with 90/72 and 60/48 Amp choices. If you can find an old HPWC, those units had 60/48 Amp choices.
