The HPWC's circuitry will be very, very minimal - only the car's load would really register. I suppose I should ask what double means? In my case, I use about 350 kWh/month or so for the car (but my normal load is between 3500 and 6500 depending on season).
Hey FlasherZ -with minimal usage, how much kWh /month do you think would be added to an electrical bill as a result of the HPWC?
I have a dedicated meter on my NEMA 14-50 outlet and here are some stats for you (as recorded by my meter, not the car):
April: 644 kWh / 2,066 miles
May: 790 kWh / 2, 474 miles
June: 719 kWh / 2,048 miles
July: 469 kWh / 1,259 miles
August: 716 kWh / 1,997 miles
This does not include some "opportunity charging" that I may do away from home (but would be minimal). I don't have a HPWC, but the kWh would be the same if I did. I just takes me a bit longer with the UMC to put the same kWhs into the car.
City waterAre you on city water or do you have your own well pump? I've seen the check valve fail which causes a pump to run too often. Hard to notice except in the electric bill. The GFI circuit in the HPWC will prevent "leaks".
Although I highly doubt the HPWC is the culprit, it is highly suspicious that the bill went up shortly after installing it (no other major appliances were installed).
Is it possible that there's an electrical "leak" in the HPWC?
I have a TED 5000 installed with three sensors (House Breaker Panel, Workshop Breaker Panel, ClipperCreek LCS-25). With that I can see the total power usage of the hose and workshop, as well as directly read how much electricity is used to recharge the EV. The LCS-25 draws between 2 and 3 watts when it isn't charging the car. I would expect the HPWC to be similar.
What about installing two NEMA 14-50's on the same branch circuit? I want to put an outlet both inside my garage and outside so I can charge even when another car is parked inside. My cable run is long and I plan to use a GFCI breaker, so running a second circuit would be very expensive. However, NFPA-70:2011 section 210.23(C) appears to prohibit multiple outlets >40A for anything other than electric stoves, but it's rather confusingly worded, and 210.23(D) appears to say the opposite so long as I put in a 60A breaker/outlet instead of 50A.
I don't think there would be any issues with it working properly, since you would only be using one plug or the other, correct? Basically like a hardwired extension cord.
ou're right in that it would likely work properly and this would be a safe use of a single branch circuit (provided you never plugged two vehicles in at once at full load); that said, I think it might depend on your AHJ.
Definitely not allowed in my jurisdiction under Section 86-300 and 86-306 of the Ontario Electrical Safety Code.
I wanted to have two 14-50s in my garage for ease of access on the same circuit and my electrician said that was against code. The outlets would not be used at the same time. I'm in Virginia. The rationale was that when I sell the house the new owner may not realize the limitation and try to use both outlets simultaneously. Similarly, wiring both outlets on separate circuits to my sub panel was against code because it exceeded the total amperage of the feed to the panel. I would have kept one of the breakers open. Same problem. I even looked into an A/B switch that would force only one outlet to be connected at a time but it was cost prohibitive.
Do you happen to have a link to the code citations, Michael? Unfortunately, unlike the States where it's codified and required to be public domain, I can't seem to find the code online for the OESA. From the excerpts I've seen, 86-306 doesn't expressly prohibit it as 86-306(1)(b) excludes the "single receptacle" wording for the 125V provision found in 86-306(1)(a), although I suspect that's just a technicality. Just curious.
Section 86-300 says that EV charging equipment must be supplied by a separate branch circuit that supplies no other loads.
