According to the story the car was in autopilot when it ran the red.
Felony charges filed in a fatal crash involving Autopilot
According to the story the car was in autopilot...
The right and correct path is being taken. This will strengthen FSD beta driver paranoia and make the system safer.According to the story the car was in autopilot when it ran the red.
guessing the driver will try to shift blame to Tesla
The article says:
"In the Tesla crash, police said a Model S was moving at a high speed when it left a freeway and ran a red light in the Los Angeles suburb of Gardena and struck a Honda Civic at an intersection on Dec. 29, 2019."
and
"Criminal charging documents do not mention Autopilot. But the National Highway Traffic Safety Administration, which sent investigators to the crash, confirmed last week that Autopilot was in use in the Tesla at the time of the crash."
When I drive with Autopilot, when I leave a freeway, Autopilot disengages BEFORE I reach any intersection and Autopilot could not, in fact, be in use at the time and place of this crash. I doubt the driver had FSD.
This is where the collision happened. The freeway ends at an intersection.Yeah, the fact that AP was used on the freeway is completely irrelevant. The driver must have re-engaged AP on a local street, and back then, AP could only go straight, and it ignored light states.
-edit-
Actually, rereading the article, what could have happened is that the car had NoA and took the exit. Then the car then auto-disengaged NoA, leaving it in AP. At which point, the car would have just plowed forward through the intersection at the base of the offramp.
Those features aren’t available in autopilot so I fail to see why it requires a mention.As a note, this crash happened before red light & stop sign recognition was an available feature.
Because the uninformed reader will assume that this crash was caused by a failure in the current release of FSD (or FSD beta), which does respond to traffic signals.Those features aren’t available in autopilot so I fail to see why it requires a mention.
So this is literally an "edge case". Where is the edge of the freeway? Navigate on autopilot should have given many warnings that it was about to disengage at the end of the freeway. As soon as the freeway ended navigate on autopilot should have disengaged. Was that before the intersection, at the edge of the intersection, half way through the intersection?This is where the collision happened. The freeway ends at an intersection.
Presumably they were also using Autosteer. When using only TACC you have to look at the road every once in a while otherwise you will leave the road. Hopefully while someone is looking at the road they will notice that the freeway is about to end.Because the uninformed reader will assume that this crash was caused by a failure in the current release of FSD (or FSD beta), which does respond to traffic signals.
Essentially this driver ran a red light while using traffic aware cruise control (TACC). There are plenty of cars that offer TACC, and none of them would claim to stop at red lights.
Presumably they were also using Autosteer. When using only TACC you have to look at the road every once in a while otherwise you will leave the road. Hopefully while you were looking at the road you would have noticed that the freeway was about to end.
No version will consistently stop for red lights and it will be your fault if you do. When FSD is out of beta then it will be Tesla's fault if it runs a red light.True, although nothing about 'Autosteer' would suggest that it brakes for red lights. Anyone who buys a Tesla today can enable AP on most streets, and it will sail right through a red light.
That said, I do think this raises a serious issue. With different versions/levels of 'Autopilot' out there, how do you know what the car will do when you enable it? Let's say my own car has FSD Beta, so I expect it to stop for traffic lights. But I borrow a friend's Tesla with base AP, and it happily runs red lights.
Same thing once FSD Beta is released and is part of the FSD package. I subscribe to FSD and my car stops at red lights. I cancel my subscription and now it runs red lights?
I remember it disengaged after exiting the highway, but it didn't stop on red as the FSD is doing now. Also, see the map submitted by Daniel in SD.The article says:
and
