fritzner
At 50 I've decided I'm too old to be doing this stuff anymore. Without a lift it is just hard on the body working on the garage floor. Technically this isn't a tough install. My problem was the first side I started on I used my impact gun to remove the sway bar end link nut. It spun it off so fast the nut came off the end of the gun and shot up into the under frunk area somewhere. May have spit out, not sure but after over an hour of looking I couldn't find it. Had to ride my bike up to the hardware store where they didn't have an exact match (nylock flange nut) so used a regular flange nut with a lock washer.
My two biggest suggestions. Remove the TORX pinch nut from the upper control arm last, after you've undone everything else. Also one install video I watched said this was a T50 TORX. My T50 was too big and my T45 was too small.
Second must do. Mark the orientation of the top hat in relation to the lower strut legs so you can get it clocked as accurately as possible. My first side wasn't exact and it was a bitch to get the bolt into the lower control arm. In hindsight I probably should've removed it, recompressed the spring and adjusted it.
The rears are simple. Literally took 20 minutes per side. Since I don't have a drive on lift, I compressed each corner with the floor jack to just where it was about to lift the car off the jack stand then tightened the lower bolts.
Overall I'm not super impressed. The car looks nice and I wanted a "mild" drop but it is almost hard to tell if the car was even lowered. I may buy the updated springs from Eibach but the thought of tearing the front end all apart again isn't too exciting and also think another inch lower in the front may be too much.
Other note. The small plastic fender clips that the frunk snaps into when you put it all back together are crazy weak. Pretty sure I snapped 3 of them on the driver's side.
I will say the car drives great. Quite a bit firmer with a solid planted feel. FWIW, I did trim the bump stop on the front as per the directions.
Thanks for the details...
So if your T50 was too big and your T45 was too small, what did you use?
