breser
AutoPilot Nostradamus
There is a problem when a car tries to do too much thinking when it comes to something as simple as stopping. Whether or not someone hits the accelerator or not the brakes should brake when they're hit. There is no "oh, sorry I was confused so I didn't do anything" or "But, you hit the gas first so obviously you consented to being thrown into the back of the truck".
Your comment has the behavior backwards. You hit the accelerator first and then apply the brake (with the accelerator still depressed) you get braking. You the brake first and you apply the accelerator (while the brake is still depressed) you get both. There is a perfectly valid reason for this. When sitting on a steep hill you may need to hold the brake until you are already applying forward force with the accelerator.
You may say "Ohh but the car has hill hold." Hill hold has very particular conditions that it works in. It's not perfect for every situation, sometimes you're still going to use the two pedal technique.
You may say "Ohh but why not use creep mode." Well some of us don't like it. Personally I don't think I like the way it makes the car drive.
Also both of these behaviors weren't available on the car when it was first put out.
This car almost invites itself into running into things, and goes a long ways into explaining why so many people have such trivial accidents with them. Drivers backing into things because the car ignored the shift. It couldn't shift because it was going over some speed threshold, but it also didn't shift in neutral to be safe. Going into neutral at least gives the user the few hundred of milliseconds of panic (when it doesn't go) to hit the brakes.
I'm not sure why you think putting the car into neutral would be any better. You're just replacing one unexpected behavior with another. I'm guessing you think that the car won't move much then because just like above you're only really thinking about level ground.
Give Tesla a little bit of credit here. They have put a lot more thought into the user interface than you think they have.
- - - Updated - - -
I'm not surprised Tesla has this ability. Apple does. Each installation package is signed. All they have to do is revoke the cert and you can no longer install it. Doesn't matter if you've already downloaded it.
I seriously doubt that Tesla would revoke the certificate to pull back an update.
It's my understanding from various things I've heard is that the car has to be able to use the 3G connection in order to apply an update. I'd bet that the car contacts Tesla and asks permission to install the update it's already downloaded. It's my understanding that this verification can't happen over WiFi.
So stopping an update being installed is just a matter of stopping to give that permission.
