At least for some of us, but apparently not all of us, if we had walk-away door locking enabled when we updated to .236 the walk-away door locking would no longer function, even though it would still show as enabled. One fix was to disable it and re-enable it. That definitely resolved the issue for MarcG. My issue resolved either as a result of a scroll-wheel reset (likely), or as a result of disabling and re-enabling mirror tilting in reverse (less likely). Those were the only two things I did after identifying the problem, and then realizing that it was gone.
So if you had walk-away door locking set, have updated to .238, and have not done a scroll wheel reset or enabled or disabled options, you should be able to at least provide one more data point.
Thanks!
