X Fan
Here's an idea for folks with USB music: upload it to Google music and stream from your phone - that interface is pretty robust in the car.
thanks...streaming quality better than bluetooth?
Same - I assumed you would connect the phone via Bluetooth.thanks...streaming quality better than bluetooth?
Thats a good idea for extra large libraries. Although, Bluetooth audio quality is not as good. If you donr have the Hi-Def sound system you probably won't notice it.Here's an idea for folks with USB music: upload it to Google music and stream from your phone - that interface is pretty robust in the car.
That used to be the case, but with the latest BT protocols and higher bit rates I can barely notice the difference. And yes my peasant ears are just fine with the standard audio so take my opinions with a shaker-full of saltThats a good idea for extra large libraries. Although, Bluetooth audio quality is not as good. If you donr have the Hi-Def sound system you probably won't notice it.
They just set defaults for sides certain apps appear on it seems. You'll just have to get used to doing a long press on the app icon and dragging it to the top/bottom screen that shows up under your finger...
I have found the opposite. I like to keep the camera open all the time, and with 7.1 put it in the bottom so that opening other apps would leave it alone. I didn't like it cause if my wife was playing with the music app, she blocked my view of the camera. Now I leave the camera on top, because it works how I wish it worked when I first got the car. Just have to retrain myself on the preferred location for it.Thanks, all, for the advice on dragging the apps to the desired location on the screen. That, does help a bit. It still does require extra effort and significantly more attention paid to the screen while driving. I can't believe I am the only one who likes to always have a specific app in one place, while exchanging the apps in the other location. I remember many people posting about liking to leave the camera app active at all times to supplement the rearview mirror.
Since updating I know longer see traffic condition highlights on the roads. Do I have to do something to bring that feature back? Between that and the loss of letters to pick through the huge number of artists on my USB stick, 8.0 hasn't been much of an improvement for me.
This happened to me too. Just open the door all the way manualy, then use the onscreen button to close. Do this a few times.Bummer, just started playing with 8.0 since loading yesterday and our driver's door latch has gone wacky! Orlando SC is slammed because of Hurricane Mathew forcing them to close last week. Off to Tampa first thing in the am.![]()
I've had two new experiences with 8.0 yesterday, one good and one not so good.
First the good, AP recognized a cyclist on the road ahead of me coming around a bend! I drive with both hands on that particular stretch of road but I like to keep AP active. The car in front of me was blocking view of the cyclist, as i turned through the curve I saw a red bicycle on my IC and a warning chimed, very cool.
The not-so-nice experience was while I was sitting at a stoplight I started to smell the exhaust fumes of the surrounding cars (I keep recycled air on always). I looked at my A/C settings and recycle was still lit, but there was a notice that something was "limited by fan speed", I tried to override all the auto settings but was still getting outside air. Finally I had to turn on BWD to get rid of the fumes in the car. Of all the media and USB complaints, this is much more of an issue for me. I think the algorithm for air flow and temp control could use some work. If the temp is set to 68 and the compressor is on and ambient air is cool enough to where the cabin might become a little cooler than the selected temperature (especially if fan speed is not set to auto) the car is now mixing in outside air to adjust the cabin air temp. (this is easily fixed by letting us turn this feature off).
If this is the case, we still dont jave a way to turn this feature off. There should be an override to recycle the air in any case. Most cars have the ability to manually select recycle. This was how it operated in 7.1, now the system is mixing in outside air for some reason.Someone pointed out in another thread that the lowest fan speed allowed in recirculation mode is 4 under 8.0.
I think that's tied to the improvement that claimed to make the air output equal for a given fan speed regardless of climate settings - which makes me wonder if the new recirculate "4" is actually the old recirculate "1" relabelled based on airflow.
Once I noticed outside air was being pushed in I changed the fan speed, went all the way up, still got outside air. I think it is more temperature dependent. I'm hoping this was just an oversight, I would hate to lose the force recycled air feature. Sitting in traffic has now become even less tolerable.If my guess is right about what's happening, and recirculate "1" no longer exists as a result, what Tesla should probably do is force the fan speed to "4" and switch to recirculate when you select the manual recirculation with a lower fan speed manually set.
Either that or renumber so that "4" is the new one for all flow settings, or if the hardware allows it define some new lower fan speeds to create a recirculate "1" again.
You may be one of the few that has not upgraded but with all the noise, you may be better off. Since you cannot go backwards I would count this as a blessing.I'm sad that after this long wait for 8.0, I still haven't gotten to experience it. SC still has my MX. I've been stuck in a rental ICE vehicle for about a week now.
