The age old torque vs horsepower/weight ratio debate about which is more important to acceleration. I have yet to hear a good physics based answer that explains why which one is a better indicator. This is complicated (on the torque side) by the gearing question and where it is measured. You can get better acceleration just by changing your gears (a frequent modification to Mustangs is to swap in 3.73 gears which can net you a couple hundred milliseconds off the quarter mile), regardless of crank numbers.Forget horsepower - 0-60 is all about torque
Just a random thought - dual motors sharing a common differential will split the power to the back wheels evenly even if one of the motors is a laggard.
Perhaps they did it that way to avoid concerns that handling could get questionable if one motor was making more power than the other?
But the historical use of a "single number" should be in the Karma's favor as the peak should be available at or very near 0 rpm vs a much higher rpm for an ICE. That 922 ft-lb peak number for the Veyron is not at 0 rpm as it would be for the Karma.Of course you can't use a single number. You'd have to average the actual torque applied over the whole 0-60 run, including any backing-off due to TC. A narrow peak isn't going to make much difference.
Motor Trend review 2011-Motor Trend-Fisker Karma (May)
Power consumption is 50KWhr/100, that's twice the roadster as a datapoint. MPG: 67 combined but really, what the hell is that number?
well I would expect a huge demand for power when the karma is north of 5k lbs. I have no idea how motor trend got 4k lbs when from any other publication has the weight estimated at 5k.
Then the CD on the Karma is not that great. it looks slick, but looks doesn't mean it's aerodynamically slick.
So it had a paddle switch for three levels of Regen. Are you listening Tesla?
Fisker is definitely more about form than function. I think he's talented enough to have gone after both though...
If there is enough demand at that price, then that's just good business.I feel like Fisker padded tons of margin into the price of the Karma to become profitable very quickly.
The Panamera gets about 24 mpg on the highway and (IIRC) I think we figured that the Karma would get about 25 mpg after it's Stealth Mode is depleted. So on a long trip, they get similar fuel economy as well.If it wants to go head to head with the porsche panamera (like Fisker claims) it doesn't have neither the performance nor price (the slower Panamera that matches the Karma is almost 30k cheaper, the Panamera that matches the Karma's price far out performs it.... and in any instance the Panamera is roomier)
