Sorry only the first sentence was in response to you. Tapatalk wouldn't let me insert line breaks to have the rest stand on its own.
How is carrying around a "giant" battery for your commute different than carrying around a similar amount of weight in an ICE (or possibly ICE+G), gas tank, etc. that (hopefully) goes completely unused during said commute?
And don't forget that "giant" battery can fit between the floor and the ground, resulting in astounding amounts of usable cargo space.
I've changed my opinion on the usefulness of PHEVs. I think that they are very helpful to bridge the gap for the moment. I'm sure you'll see in about 5 years, a lot of Volt owners making the complete switch to pure EVs.
Yup. Plus the presence of lots of PHEVs will cause more infrastructure to be built, not the quick charging, but at workplaces, parks, and hotels and other destination points that people use the gas engine to get to.I think this will happen because of two things: first, drivers will realize that they aren't using the gasoline range extension that much, and second, charging infrastructure will be much better in 5 years, which will reassure people.
A related point: In addition to the weight penalty, having to pack a dual powertrain into the car takes up a lot of space -- the exact opposite of a pure EV which frees up space. The Volt only seats 4, and it is small inside. The Honda Accord PHEV has a spacious cabin, but a trunk that is pathetic. Ford's C-Max has less compromised in this regard, but the rear cargo floor is raised compared to the hybrid (due to taller battery pack).
He should also chide himself for muddying the landscape with "EREV/EVER" FUD.Fisker chided the automotive press for not taking care to distinguish between plug-in hybrids and pure electric cars.
In case anyone was not aware, the Karma weighs in at 5300lb. I don't understand how Fisker can make the arguement about toting around a giant battery pack when his own product is toting around a whole lot more.
I agree with the other posters that PHEV will be the bridge over range anxiety. It's unfortunate that most won't make the leap to BEV right away, but I do think that Tesla's presence in the automotive market resulted in an inflection point regarding the sentiment surrounding BEV's. The sales will come.
My Volt is a a 40 mile BEV and a 360 mile PHEV after that. Hence EREV. Full electric, full throttle up to 101 MPH. (vs PHEV kicking on ICE under throttle or at certain speeds)
it will be obvious that the battery is a non-issue
Agreed. We're going to have a model X and an old NSX. That should be completely practical, no?Please elaborate on that? I think the only way that would be the case is if the car can fulfill all needs without inconvenience or need of a backup ICE. I know personally, if we were only able to have one car in our household, the S (or any other current BEV) wouldn't be it.
Actually it is completely different.How is carrying around a "giant" battery for your commute different than carrying around a similar amount of weight in an ICE (or possibly ICE+G), gas tank, etc. that (hopefully) goes completely unused during said commute?
Not just that. Driving 100 000 miles on a 40 kWh battery pack means around 700 full charge/discharge cycles, while driving 100 000 miles on a 85 kWh battery pack means around 380 full charge/discharge cycles. It's obvious that using each cell more means more degradation.85 kWh battery has unlimited warranty, 40 kWh pack has a 100k mile warranty limit. This is exactly because higher average current levels running from 40 kWh cause more internal damage than in 85 kWh.
I haven't checked, but it wouldn't surprise me greatly if it were 8 years. The reason is that plug-in hybrids use more expensive cells with a longer life span (as do cars like the i-MiEV and Leaf relative to the Model S).Now consider a measly 16 kWh battery of best current plug-in hybrids. What is the warranty?
