I have recently installed fog lights to my 2021 Model 3 SR+ (non indicator ones) which I got from AliExpress and didn’t have the wiring as RWD model 3’s don’t have it stock. I’ve since obtained the wiring through Amazon
There’s no install videos online and the threads here are quite extensive yet I found no one has a simple answer to where the wiring gores. I’ve attached pics here, if someone can please edit the pic on paint etc and label where they’re all plugged into it would be so helpful not only to me now but others in future. Thanks for your help as always !
Get the front bumper fascia off the car and simply remove the old harness, you will see exact how it runs then, and will find two extra connectors for the fog lights on the new harness. Thats it.
There is no old harness mate.
I’ve installed the lights now just making sure I have an idea of what’s needed beforehand & can’t work out why they gave me these extra plugs
White is obviously for indicators which I don’t need and can by-pass but these extras.. wierd.. anyone?
Upvote 0
Done, 4.5 hours but finally worked it all out. Found a good video on YouTube to gain access through the firewall
The 2 separated wires connect via the white cable which runs along inside the boot lid, they connect to the rear break lights.
Hope all this helps someone else in the future.
Upvote 0
Hello, do you have the Amazon link to this wiring harness? I cannot find it anywhere and have the same issue.
Upvote 0
