The max. 800A vs 600A has been stated since the early days in the manuals.
But there are some interesting things. From the CAN data we know the following:
Performance max:
Rear: 246kW @ 337V ~730A
Front: 186kW @335V ~ 555A
AWD max:
Rear 220kW @ 350V? ~ 628A
Front: 132kW @ 350V? ~ 377A
The battery voltage wasn't shown in the video posted above for AWD, but let's assume it's around 350V as this is what the Performance drops to when pulling roughly the same as the AWD. Can you do a new test, STSUKX?
According to the manual (if you add the numbers together, not sure you can as it's at different rpm) you get 339kW/455hp for Performance and 317kW/425hp for AWD (so a 30hp / 7% difference).
However, according to the EU spec's I posted before (numbers provided by Tesla to EU) then each motor should be able to output (pre-2019.36 5% update):
AWD
Front at 155kW / 208 hp
Rear at 195kW / 262 hp
Total: 350kW / 469 hp
Performance
Rear at 205kW / 275 hp
Total: 360kW / 483 hp
I personally trust the EU numbers more than the manual for some reason as they seem to fit better with reality on the Performance model.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
And we know the Performance has been dyno'd at 464hp and the AWD at 367hp before the first 5% upgrade, so after 2 x 5% upgrades, they should probably real world measure around 512hp and 405hp respectively. But would be fun to see new dyno results (together with CAN data) after the 2019.36 update.
Performance max:
AWD max:
AWD
Performance
