Hey ranova,
Thanks for posting this. Looks like a great solution. I am hesitant about these brackets that cover the vent. Yours looks fine.
I must be dense, but it's not clear to me how this attaches. Does the bracket tape onto the underside of the front bumper? And then there is a removable nut that can be screwed on and off?
The Model 3 bumper is slanted a bit. Did you have to bend the bracket to have the license plate fit vertically?
Have you tried to pry it off? You don't think there is a chance this could come off on the highway after some time? Lots of vibration over time has to have an impact on the ability of the tape to hold, no?
Yeah, you are correct. The picture in the product page has the mounting piece flipped around for some reason. I did not have to bend the bracket at all, it was already slightly bent outwards, which was good. The directions say that you want it actually angled inwards at the top so that it touches the car. This is likely so it doesnt rattle when youre driving around. It does have a rubber stopper at the top so it wont scratch your car. It has a large removable nut that takes 5 seconds to get off when you want to remove the plate. Picture of what it looks like, semi bent:
I havent tried to pry it off, but per the product page, they hung a 10lb weight off of it and it didnt budge at all. They also drove around at 100mph and it didnt budge. Its definitely the strongest double sided tape I've witnessed so far. I havent drove around with the plate on yet, I'm going to let it sit and cure for the full 72 hours. Additionally, I will likely only keep it on while parked in SF, where the parking maids will ticket you without a front plate
It was initially tested by mounting the base to a painted surface with the bracket attached and we let it sit for a week; it didn’t move. Then we hung 10lbs of weight off the mount with the bracket attached and let it sit for a week; it didn’t move. Then we mounted it on a 2015 Mustang GT, took it up to 100mph using the 3M tape mounting option; it didn’t move.
I will email the guy to see if he would make custom ones for the Model 3 where we can screw it in at the bottom of the plate (and maybe use double sided tape near the top) so then it wont cover any of the vent. But again, this is not as bad as some other mounts as there is still room for air to get in the vent
