Pdubs
Ingesting large quantities of LSD
it won't matter. Nothing matters anymore.You having 24.3.10 depression makes me want to burn my check instead of waiting to see if 24.4.1 is real.
yayBurned check got 24.3.10
Am I confused, is there another place where you can set it to be "aggressive"? The only setting I know of is "chill/average/assertive". Or is this case of a collective projection of assertive = aggresive?Interesting, mine consistently stayed above the speed limit (5 - 10 mph) in limited testing (an hour or so). Not sure if it makes a difference but I have mine set to "aggressive", slow was never an issue.
Whoops, going from memory which is always dangerousAm I confused, is there another place where you can set it to be "aggressive"? The only setting I know of is "chill/average/assertive". Or is this case of a collective projection of assertive = aggresive?
Sure that Tesla was getting on the freeway but rather than merging into the open lane she decided to jump 2 lanes into mine. Most likely manual driving.Could you explain what happened in that video?
They will, but it will stop a few cm too far from the line and pick the wrong spot so @AlanSubie4Life won’t like it and Mrs. @AlanSubie4Life will want to sell the carAnyone think Tesla will integrate Park Assist with FSD so at the end of the drive the car will show parking spots to select from then park the car for you? Not sure how the UI would work though. Or is that going to be reverse summons (i.e. banish)? I do find I am using the Pin placement instead of just an address to try and get me into the parking lot instead of just in front of the building. Park assist does need to be speedier for it to be really functional.
A few centimeters? ... try 1 millimeter!They will, but it will stop a few cm too far from the line and pick the wrong spot so @AlanSubie4Life won’t like it and Mrs. @AlanSubie4Life will want to sell the car
Uncheck the streaming source that has you playing Freddie Mercury on continuous loop. Then your world will open up.it won't matter. Nothing matters anymore.
No, clearly she was using the Chevy Cruise stackSure that Tesla was getting on the freeway but rather than merging into the open lane she decided to jump 2 lanes into mine. Most likely manual driving.
Just to clarify, the car accelerates somewhat aggressively up to about 5 MPH below the speed limit, then slows way down. The accelerator taps I was referring to were to get it past those last 5 MPHOdd, my car accelerates too quickly for my taste. Actually pushes you back into your seat.
I'd rather get my dk slammed in a car doorUncheck the streaming source that has you playing Freddie Mercury on continuous loop. Then your world will open up.
Interesting situation. Clearly you can't teach your teenager to drive if using FSD. But once the learner's permit Is over and it's time for solo drives - will you allow that without FSD?Ok, just returned from a trip with my teenage student driver. No interventions. Primarily because I couldn’t reach. I definitely like 12.9.8.7.6.5.4.3.2.1 better. Excuse me while I pour myself a drink…
yeah, that didn't work either. Any other bright engineering ideas?Uncheck the streaming source that has you playing Freddie Mercury on continuous loop. Then your world will open up.
I don't know about you, but that would certainly matter a great deal to me.I'd rather get my dk slammed in a car door
This is why I refused to (and may continue to refuse to) use FSDbeta/S because I'm still battle scarred from that experience decades ago. Then, the benefit to me training a new driver was that I could cease to drive them places, then they would run errands for me (and both did), and eventually they would be able to make life choices that required driving a car, either stick or automatic. And they have.Ok, just returned from a trip with my teenage student driver. No interventions. Primarily because I couldn’t reach. I definitely like 12.9.8.7.6.5.4.3.2.1 better. Excuse me while I pour myself a drink…
If its not part of guardrail or if its not "10 minutes" ?If it's not there's probably a system design problem.
I guess it's time to buy the most premium X subscription available, and grovel to Elon until he notices you. Hopefully he won't ask Tesla staff to check your history.yeah, that didn't work either. Any other bright engineering ideas?
Are you sure it wasn’t Metallica?Uncheck the streaming source that has you playing Freddie Mercury on continuous loop. Then your world will open up.
