It never showed 305 miles. It never shows WLTP.Hi all
My Model 3 was registered in Jan 2023 and has a max range of 305 miles (WLTP). It’s done 3,000 miles and has 19” alloys.
I set the car to charge to 100% and when it completes, the range is just 266 miles.
Any advice greatly appreciated
As others have said, if it won't charge past 87%, put in a service ticket. As for miles, set your display to % and forget about it.
I think the title is misleading and that the car charges to 100% but that only displays 266 miles, which is the concern. AAKEE probably has the answer: the car doesn't show WLTP miles, it shows EPA miles. All is normal
While that is the case for the non-EPA range with 19" wheels, I'd still expect 272 to be the max in the car regardless of wheel selection.. 266 for a RWD vehicle (which is rated for 267) sounds extremely normal and correct
Model 3 P 2021 (min bugged out but a few others do change range with wheels)While that is the case for the non-EPA range with 19" wheels, I'd still expect 272 to be the max in the car regardless of wheel selection.
There have been claims made that for this vehicle the range displayed does depend on the wheel selection, I haven't seen the evidence for that (it would be very easy for that to be produced, and sorry if I missed the post with that info). At the moment the only Model 3 vehicle that changes rated range display based on wheel selection that I'm aware of is the 2020 Performance.
Again, not saying that is the only one, it's just the only one I'm aware of.
But in any case 266 rated miles out of 272 (not 267) for a vehicle from January 2023 is also very normal; just a couple % capacity loss according to the BMS estimate.
If anyone has evidence that the wheel selection does make a difference for RWD definitely post it (basically just have to change wheel selection and show the 100% charge level with each wheel selection).
Yes, aware of this, since you've mentioned it before, but unclear to me whether it is intentional or not since you've also mentioned it's buggy. So for now I've been disregarding this until I'm made aware by someone that it is all working perfectly correctly.Model 3 P 2021 (min bugged out but a few others do change range with wheels
