StealthP3D
I'm tempted to put it on my lift to find out... It sure feels like it.
That comment just shows you don't know how AWD EV's like the Model 3 work. An important part of the equation that determines how much power to send to each motor is based upon how much load is on each motor. You are going to learn very little with all wheels in the air.
From an efficiency standpoint it would make sense to send all torque to the rear wheels at low loads.
There are two kinds of torque (or, more accurately, two different places to measure it) when it comes to discussing how power is transferred on a sheet of ice.
There is the torque to the rear wheel axles (I'm ignoring the motor torque, before the gear reduction) and there is the torque applied to the driving surface (by the tire's tread). In a rear-biased AWD like the Model 3 they are two different things. Because without positive torque applied to the front axle, it would be up to the torque applied at the rear tire tread to turn the front tire, axle, gear reduction and front motor. And in an RWD car that is exactly what happens (minus the front motor and gear reduction). The Model 3 powers the front motor before the rear tires slip to avoid using the torque applied by the rear tread in order to turn the front wheels. As the guys working on the CAN bus data continue to map out the data streams, this will become more apparent.
But let's take a step backward. It's obvious that some of you feel the AWD Model 3 has less sure footed acceleration than other AWD cars and, when deeper into the throttle, I agree. That's one of the things I prefer about the Model 3's snow/ice handling because the heavier workload applied to the rear wheels for acceleration helps preserve directional control of the front wheels. And that is a big plus.
Another factor, one that I wrote about earlier deserves a re-visit. It's about how tire wear changes snow/ice grip. I'll copy it below, pay special attention to the part relating to how heavy accelerations on abrasive surfaces (like pavement or snow and ice with embedded sand/gravel) can wear the tread blocks into an unfavorable shape for grip under acceleration. And don't underestimate how the prodigious torque of even the lowly AWD Model 3 can cause even average drivers to wear their tread blocks into unfavorable shapes for good acceleration on snow/ice. Low tire pressures can exacerbate this phenomenon. I believe this is amplifying peoples reaction to the naturally rear-biased nature of the AWD Model 3. Because we all know how addicting that torque can be when we have the traction to use it (and even sometimes when we don't,). You will need to expand the quoted text.
Another factor to consider is that how the car is driven on bare or bare/wet pavement affects snow and ice traction due to the tread wear pattern differences that various driving causes. A tire that is driven relatively normal and conservatively on bare pavement wears into the best shape for overall ice and snow traction. A tire that is accelerated hard, near or exceeding the traction limit but never braked hard has poor ice/snow acceleration but better ice/snow braking. A tire that has been braked hard repeatedly but always accelerated gently will have good ice acceleration but poor ice braking. Tires that have been pushed hard on pavement corners will have reduced cornering ability on snow and ice because of it. Some kinds of winter conditions cause treadwear that naturally reduce traction even when driven with the flow of normal traffic. Pavement that has consistent but reduced traction due to water and coldness can cause micro-slipping even when not being driven particularly aggressively that can cause treadwear that is not favorable to ice snow traction.
None of these tire factors are unique or particular to the Model 3 except perhaps for the tendency of Model 3 owners to make use of the impressive motor torque when they have the bare pavement with which to do so and to limit hard braking due to the ease of regen braking. So Model 3 owners could be inadvertently wearing their winter tires into unfavorable tread wear patterns for ice/snow hill climbing/acceleration.
