gearing change
Discussion in 'Roadster' started by twiersum, Sep 13, 2017.
Tags:
  1. twiersum
    twiersum Member
    canada
    Has anyone looked into running a lower gear ratio in the transmission for racing?
  2. supersnoop
    supersnoop Tesla Roadster #334
    Pflugerville
    I remember seeing some sort of experimental differential for sale a few months back. Maybe that would provide the ratio you're looking for. A lower ratio would make the car faster, but not as quick. Is that the goal?
  3. JHWJR
    JHWJR Member
    Pittsburgh PA
    I'd be up for a re-gearing that would provide less acceleration and more range. :) There seems to be enough torque to go with a longer gear ratio...
  4. jeremyz
    jeremyz Member
    I think that there were some cars that used the same Borg Warner gearbox as the Roadster but with a lower gear ratio. So, it might be possible to buy a different set of gears. Maybe EvWest would know about this?
    http://www.evwest.com/support/borgwarneredrive.pdf
  5. Roadster
    Roadster Member
    SoCal
    Here's the most recent post about the LSD being referenced. The original post from 2015 with addl. photos can be found here.
  6. spaceballs
    spaceballs Member
    Sammamish
    Gear change will not help that much for more range, i.e. the gains would be the motor efficiently delta in RPM.
